Vlang29's H23VTEC Rebuild
Old Apr 24, 2008 | 06:54 AM
vlang29's Avatar
Default Vlang29's H23VTEC Rebuild
So here's my situation:
https://honda-tech.com/zerothread/2281315
thought i'd start a new topic since this isn't exactly oil pressure issues anymore...
A few mains were beginning to flake, and the one was burnt pretty good. The crank is toast.. The bearing oil grove is actually imprinted into 180* of the crank.. I don't know what the limits are of what a machine shop can (realistically) do to save the crank, but i don't think it's salvageable. I really can't believe this thing was running as good as it was.
My original plan was to re-use the 95mm crank and use my JDM H22 pistons i have laying around. With a .045 headgasket, this would put me about 11.1:1, which i am thinking to be about right for me.
but the biggest problem, of course, is that my financial situation doesn't exactly yield "just send me a bill when you're done" kind of machine work.
The H22A4 short block i found locally for $300 turned out to be an SH block. After digging in the H/T archives i found what it takes to make the intermediate shaft work, so i'm starting to lean a little towards just grabbin that SH, slappin on my H22A head and M2B4 and be done.
I know i would really love that high comp 95mm build, but my current financial situation could be a bit hampering... Without selling my soul and my beer fridge, the most i can spend is appx. $6-700. I have a hunch that this budget is no longer going to cover the 95mm build...
ANY COMMENTS OR RECOMMENDATIONS/SUGGESTIONS ARE WELCOMED!
Modified by vlang29 at 10:32 AM 4/24/2008
Old Apr 24, 2008 | 07:46 AM
vlang29's Avatar
Default Re: Vlang29's H23VTEC Rebuild (vlang29)
I'll also add that the motor had plenty of oil when scat hit fan, i have run mobil 1 full syn since i bought the car at 133,000. It was run out of oil once, at around 190K, when the oil cooler seal blew competely out. (lost all 5 quarts in 2 miles!!) But i haven't had any issues until now, 255,000mi.
It has been a quite strong motor too, I know g-tech's aren't very accurate, but I did a run when she was at about 240,000 showed me at 14.0@102.1, on scab tires in the winter.
For your viewing entertainment:
That ridge in the middle of the main journal is only present 180* degrees crank rotation.. other side looks fine!
i estimate that ridge to be appx .025-.035"!!! It is ridiculous!
toasty toasty
Modified by vlang29 at 10:57 AM 4/24/2008
Old Apr 24, 2008 | 08:00 AM
Giant_Bean's Avatar
found some cranks for you on this site, worth a look, new for just over $300.
http://www.importperformanceparts.net/
Old Apr 24, 2008 | 08:25 AM
vlang29's Avatar
Default Re: Vlang29's H23VTEC Rebuild (Giant_Bean)
not bad at all, that might me the way to go, thanks!
Old Apr 24, 2008 | 10:39 AM
Acidcrakker's Avatar
Sell your Soul
I have a H23 Crank I might part with if the price is right
Old Apr 24, 2008 | 12:37 PM
vlang29's Avatar
Default Re: Vlang29's H23VTEC Rebuild (Acidcrakker)
i got the crank out now, and more bad news.. the saddle is totally wasted. It is mushroomed over the edge enough that you can see it with the naked eye.
Old Apr 24, 2008 | 01:24 PM
98vtec's Avatar
moderator emeritus
i think this thread is improperly titled
Old Apr 24, 2008 | 02:45 PM
bluedlude's Avatar
Default Re: Vlang29's H23VTEC Rebuild (98vtec)
wow, thats really bad. if you ran the block home with no oil that would explain those smoked bearings.
Old Apr 24, 2008 | 05:17 PM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">i think this thread is improperly titled </TD></TR></TABLE>
it is now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">wow, thats really bad. if you ran the block home with no oil that would explain those smoked bearings. </TD></TR></TABLE>
yeah, but i didn't, and that was two years and 65,000 miles ago
Old Apr 24, 2008 | 05:42 PM
bluedlude's Avatar
there only one thing that can reip the third bearing layer off like that. HEAT! were they OEM or ACL bearings? you probably got the groove from the bearing material getting into the oil groove and i guess notching the crank. that sucks, but the 180 degrees is still kinda weird.
Old Apr 24, 2008 | 05:45 PM
vlang29's Avatar
Default Re: Vlang29's H23VTEC Rebuild (bluedlude)
OEM, engine has never been apart
Old Apr 26, 2008 | 05:41 PM
vlang29's Avatar
my awesome oil pickup screen
victor.ek4
Jun 2, 2010 12:47 PM
johnnyonth3spot
18
Sep 5, 2009 08:24 PM
b20vtech
26
Jul 28, 2008 12:33 PM
vtec-gorilla
Nov 26, 2006 05:19 PM
-16V-
Nov 11, 2002 05:35 PM
