problem getting car to stay running need help!!!
Old Apr 24, 2008 | 05:27 AM
mattmelton08's Avatar
Default problem getting car to stay running need help!!!
ok so i have a d16a6 motor with leaky vavle seals and all of yesterday it would not stay running. it would get enough power to run for like 3 sec. once i turned the key but then it would just die. I bought new plugs, ditributor, rotor wheel, and wires. Yet this still did not fix my problem. checked the fuel pressure it was good. My timing might be off but if you have any suggestions i would really appreciate it.
Old Apr 24, 2008 | 10:14 AM
sgallagher's Avatar
Default Re: problem getting car to stay running need help!!! (mattmelton08)
What is your fuel pressure at?
Does it stay running if you open the throttle?
Was it running before?
Any fault codes?
Old Apr 29, 2008 | 05:27 AM
Default Re: problem getting car to stay running need help!!! (sgallagher)
Their is fuel pressure but i dont know the exact pressure rating. Before i used to have to open the throttle to have to get it started before but i did not have to it every time and now it will not run it will start for five seconds and then shut right off.
Old Apr 29, 2008 | 06:52 AM
MoreBoost!'s Avatar
ur idle maybe too low?
DawgC2
Mar 10, 2012 12:11 PM
ken2830
Jul 5, 2011 07:33 AM
ken2830
Nov 3, 2009 09:28 AM
Used2beAb16
Jun 28, 2006 09:34 PM
