Anyone think a test pipe wil help save gas on an 0BD-1 Honda???
Old Apr 23, 2008 | 09:14 PM
jdmeg6118's Avatar
Default Anyone think a test pipe wil help save gas on an 0BD-1 Honda???
Anyone think a test pipe wil help save gas on an 0BD-1 Honda??? Test pipe or cat with OBD-1 wondering if you can save gas cuz of less restriction anbody?
Old Apr 23, 2008 | 09:15 PM
Eran's Avatar
HT White Ops
Default FV-QR
No . . .
Old Apr 23, 2008 | 09:18 PM
jdmeg6118's Avatar
Default Re: FV-QR (Eran)
So with OBD-1 you will waste more gas with a test pipe instead of cat? Why?
Old Apr 23, 2008 | 09:21 PM
Eran's Avatar
HT White Ops
Default FV-QR
I think you'd waste more gas because Honda's RnD department of trained automotive engineers know more about emissions controls and fuel economy than some guy with some straight pipe and a welder.
I'll leave it at that.
EF_9's Avatar
Default Re: Anyone think a test pipe wil help save gas on an 0BD-1 Honda??? (jdmeg6118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6118 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone think a test pipe wil help save gas on an 0BD-1 Honda??? Test pipe or cat with OBD-1 wondering if you can save gas cuz of less restriction anbody?</TD></TR></TABLE>
restriction thats what i was thinking.hmmmmmmmmmmm your just going to have to try it out yourslef
Old Apr 23, 2008 | 09:26 PM
jdmeg6118's Avatar
Default Re: Anyone think a test pipe wil help save gas on an 0BD-1 Honda??? (EF_9)
I ran an 0BD-1 civic EX with a test pipe and felt nothing i was just wondering if anyone had a different expirence then i did maybe in OBD-0
Old Apr 23, 2008 | 09:28 PM
Jimmy's Avatar
Global Moderator
Test pipe will make your stock ecu run rich.
Don't do it if you want to save gas..
Save Gas = New plugs, plug wires if needed, how many miles is on your O2 sensor?, replace fuel filter, try running some seafoam/injector cleaner..
Old Apr 23, 2008 | 09:35 PM
EF_9's Avatar
if you already drove with one and it doesnt make a difference i guess not...
i guess just follow what jimmy said thats a better idea
oh and i never knew it will make your car run rich due to stock ecu thanks for the info man
Old Apr 23, 2008 | 09:37 PM
jdmeg6118's Avatar
Default Re: (Jimmy)
Thought that went for 0BD-2 with o2 sensor on cat? OBD-1 has only one o2 sensor? Inlighten me please
Old Apr 23, 2008 | 09:39 PM
EF_9's Avatar
well either way whatever test pipe you use it wont save gas as for the OBD1 itll prolly just pull out CEL codes
Old Apr 23, 2008 | 09:40 PM
jdmeg6118's Avatar
Default Re: (EF_9)
I knew a test pipe will make and OBD-2 ecu run rich if now setup right..im not sure about OBD-0 OR OBD-1 though.
Old Apr 23, 2008 | 09:42 PM
jdmeg6118's Avatar
Default Re: (jdmeg6118)
I had no code's with my OBD-1 test pipe.I have heard people say that they save lot's of gas with a test pipe on OBD-1 im not sure..
Old Apr 24, 2008 | 12:30 AM
bigsyke's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Test pipe will make your stock ecu run rich.
Save Gas = New plugs, plug wires if needed, how many miles is on your O2 sensor?, replace fuel filter, try running some seafoam/injector cleaner..</TD></TR></TABLE>
Please tell me how a test pipe would make you run rich? I need to know, because my thoughts were the 2nd o2 only took readings from the catalyst, and did 0 correction to the A/F readings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">I think you'd waste more gas because Honda's RnD department of trained automotive engineers know more about emissions controls and fuel economy than some guy with some straight pipe and a welder.
I'll leave it at that.</TD></TR></TABLE>
This is true, however me personally I think the emission restrictions force vehicles to make great sacrifices to adhere to emission federal laws. Im sure they could probably make an engine more efficient if there werent as tight restrictions.
I look at it like our justice system. The liberal system prevents the police from doing an excellent efficient job protecting our nation, because felons have more rights than we do when tried
Old Apr 24, 2008 | 04:04 PM
jdmeg6118's Avatar
Default Re: (bigsyke)
RUN rich?
Old Apr 25, 2008 | 01:18 PM
93beccalx's Avatar
I don't see how it could make your car run rich unless the o2 sensor is located in the cat. I have a B16a2 w/ ITR 4-1 headers and run a straight pipe all the way back. No CEL, but the car does run rich, probably d/t bad tuning on Crome.
Old Apr 25, 2008 | 03:41 PM
Jimmy's Avatar
Global Moderator
I was thinking about the secondary O2.. Sorry
check out this thread..
https://honda-tech.com/zerothread?id=1398726
PowerLeg
Apr 15, 2010 11:37 AM
mildly.interesting
Dec 23, 2004 09:07 PM
mingchi69
Nov 29, 2003 04:37 PM
Petah
Oct 11, 2003 07:59 PM
