Catalytic Converter.. needed... three way connection
Hello, I need a Cat. converter with a three way intake that has one connection hole a little longer then the other two... or just the three way connector itself(preferred)..
Heres the deal. I just put a F22b DOHC in my accord... Now my existing muffler pipe will not connect to my stainless steal headers, and I dont have a coupling to connect the two pipes together. "Cant weld stainless and metal" So I either need a steal cat converter or a steal three way coupling so I can weld it to the existing pipe..
I want to keep the existing exhuast muffler due to a low budget..
If you know where I can get one, or have one you want to turn loose of.. Let me know.
Thanks Ron
Thanks Ron
Yes that is what I am looking for.. I do not have the flange..... I need the converter side flange .. I need either one cut off of a converter or the converter itself. The engine I have is like a H23 and I put Prelude headers on it which have a 3 way flange ,... the car is an accord and the accord pipe had only 2 flanges..( and has been cut off so I can weld a three way flange o)n.... (prob is I don't have the flange to weld to the car side)
Im looking to see if anyone might have a flange they might want to sell me or know where I can buy one..
Thank You for your help..
OK ,, I got the prob fixed.. turns out the smaller three way connection is the same on the prelude as it is on the accord.. Ordered new cat, and used the smaller three way connector,,
Thanks for your help
