keep jdm foglights on a turob eg
is there any piping or ic kit that have enough clearance so that you can run the piping and still keep your foglights cause i have a setup on there right now that will no way allow me to do that so if anyone can help thanx
if you get a IC with the inlet's and outlet's are ALL the way at the bottom, it can fit.. it's close, and you MAY have to cut a LITTLE bit off the bottom of the bracket, but it should fit..
car isn't turbo'd yet, but everything was cut and fitted and the piping will fit..
buda18
Aug 18, 2006 12:06 PM
crxsiperf
May 6, 2005 10:11 AM
