Firing order
Old Apr 23, 2008 | 01:50 PM
mavvrik's Avatar
Default Firing order
Hey guys. Can't get the car to start. Not sure if it's firing order or something else. So I need some second opinions, does this look correct? It's a 1997 Accord SE. Some help...or just answers would really be appreciated. Seems like NO ONE can help me on this for some reason :/
This is apperently what it should look like?
Old Apr 23, 2008 | 03:41 PM
WhiteyMcBlakc's Avatar
last time this happened to me, it was several things....bad news is i cant remember what the problems were....so i hope someone on here can help you out.
Old Apr 23, 2008 | 04:08 PM
hondadude's Avatar
Default Re: Firing order (mavvrik)
Did this problem hapen right after the plug wire change?
Are you getting spark out to the plugs?
Can you hear the fuel pump run a few seconds when you turn the key on?
Old Apr 24, 2008 | 04:29 AM
mavvrik's Avatar
Actually guys, after a long grueling week of working on this car non-stop, I finally got it running last night. She's running super strong too
Old Apr 24, 2008 | 07:18 AM
nicokpe's Avatar
sorry can't help.. so what you had done it can be running again??
Old Apr 24, 2008 | 12:57 PM
Turbowa's Avatar
Default Re: Firing order (nicokpe)
If you still really want to know the firing order on every honda 4cyl is 1-3-4-2.
Old Jun 25, 2012 | 10:31 AM
peter t's Avatar
I know you already figured this out but for future people I thought I would tell you what I found. I don't know as much as you guys by far, but I just replaced my O-ring seal on my distributor and as a dummy would labeled the wires off the cap but didn't mark were they came off, duh!. So I had to find the correct order. Your cap should have an "A" marked on it to tell you were your #1 should go. So on my car F22B2 engine my #1 went were your #2 is then #2, #4, #3 counter clock wise in that order. Hope that helps
Old Jan 15, 2022 | 01:03 PM
tonio405's Avatar
How man thank you so much I thought I had replace my fuel pump but it was just the wire order thank u
autech
Jul 24, 2015 05:20 AM
oldschoollove
14
Jul 19, 2009 03:20 PM
AnDy327
Oct 26, 2007 12:26 PM
00WhiteEKy
Apr 25, 2003 09:39 PM
