Firing order
Firing order
Hey guys. Can't get the car to start. Not sure if it's firing order or something else. So I need some second opinions, does this look correct? It's a 1997 Accord SE. Some help...or just answers would really be appreciated. Seems like NO ONE can help me on this for some reason :/
This is apperently what it should look like?
Re: Firing order (mavvrik)
Did this problem hapen right after the plug wire change?
Are you getting spark out to the plugs?
Can you hear the fuel pump run a few seconds when you turn the key on?
Actually guys, after a long grueling week of working on this car non-stop, I finally got it running last night. She's running super strong too
Re: Firing order
I know you already figured this out but for future people I thought I would tell you what I found. I don't know as much as you guys by far, but I just replaced my O-ring seal on my distributor and as a dummy would labeled the wires off the cap but didn't mark were they came off, duh!. So I had to find the correct order. Your cap should have an "A" marked on it to tell you were your #1 should go. So on my car F22B2 engine my #1 went were your #2 is then #2, #4, #3 counter clock wise in that order. Hope that helps
oldschoollove
14
07-19-2009 03:20 PM
00WhiteEKy
04-25-2003 09:39 PM
