mods to get more juice out of my D16Y5 w/o turbo,sc, or nos?
Anyone know what else i can do to get more juice out of my D16Y5 w/o turbo,sc, or nos? Throttle body, which ones would fit my ride?
EX intake manifold.
B18C1 trottle body.
EX tranny (Biggest difference)
Port and Polish
1 layer Head gasket
LSD
Better tires
Better suspension
Lighter flywheel
Stronger clutch.
What else do you want?
B18C1 trottle body.
Port and Polish
1 layer Head gasket
LSD
Better tires
Better suspension
Lighter flywheel
Stronger clutch.
I like
the HX tranny 40 1st 70 2nd 110 3rd
I always beat my friends 96 EX when both of our cars were stock even when he had a AEM cold air intake and i didnt both cars han s/s kits his has 89000 miles and mine 110000 How much does the throttle body go for? my suspension isnt good? whats better?
D16Y5 = HX motor
it already has a EX manifold
HELL NO IT DOESN"T the runners are tiny on the HX and the HX has an EGR valve.
It has the same positioning as the EX but in no way is the the EX manifold.
Spade who used to be an avid HX preacher, you wanna know about the HX ask I can answer.
B18C1 trottle body.
Would this also work for a D16Y8??? And how much power could I expect with Intake and exhaust??
Thanks!!
Thanks!!
I like
Yeah it is nice not having to shift for 10 seconds but, the shorter gears help in speed like it is nothing. THe engines put out almost the same amount of power.
THe HX actually has more midrange (quite, don't tell anyone that).
What kind of ricer is that off of the throttle body? i'm pretty new at this Rice deal used to and kind of still am a vw fan. how much of a difference would a ex head do? would i have to change ECU's?
my hx still runs mid 15's in the 1/4 mile @ 86-87mph almost completely stock, how many EX's do you see doing that?
The trottle body is off of an Integra GSR. It is a 60mm as apposed to the 56mm that the Civic is.
No, you don't want to get an EX head. The HX has roller rockers. The cams have a higher lift (although I don't know about duration).
[Modified by Spade, 11:47 AM 7/12/2002]
On the intake it has 3 and the HX 2
On the exhaut they both have 2.
The HX has one lobe that is larger than the other. At 2700-3100 (gas pedal pressure pending) the lifters lock on the higher lobe.
https://honda-tech.com/zerothread?id=101349
[Modified by bretx0r, 7:46 PM 7/12/2002]
ive run much better since then. I got a 2nd place trophy running 15.8 all night. the only mods to my HX are an intake muffler and a short shifter
[Modified by bretx0r, 8:11 PM 7/12/2002]
I have seen mustangs V8!! That screw up there raction time like that....1.0!!
And burn up for a shitty 60 ft. 2.4!!! And pull a somewhat decent run out of there ***.
15.8 with a 60ft of 2.4 NO WAY IN HELL on a stock HX!!!
[Modified by Spade, 12:18 PM 7/12/2002]
all and all, it`s still a mid 15, who freakin cares. That`s why I don`t attend drag events. Nothing worse that watching 21632178631763781 15-20 second Hondus.
