help me with my turbo setup
Old Apr 23, 2008 | 12:35 PM
xkilacamx's Avatar
Default help me with my turbo setup
i found a deal for a d series turbo kit but i have a couple questions about it, my car is a 2000 honda civic dx automatic. i know its not a supra or a 300zx but still it would be nice to beat an si or a mustang every once in a while. and with gas prices in my area going up to 3.60 i have some concerns. my friend knows how to setup and install the turbo so money is not an issue but the turbo will use up a lot of gas right? and also i know i have to get a bigger exhaust and some other things but what else do i need to know. its a greddy turbo and i dont know the trim or anything else but any help with this would be great. thanks
Old Apr 23, 2008 | 12:36 PM
ke98248's Avatar
Default Re: help me with my turbo setup (xkilacamx)
THE MOST IMPORTANT THING FOR YOU -- AN AUTOMATIC TRANSMISSION WILL NOT HOLD MORE HP/TQ WELL AT ALL. IT WILL LAST FOR A FEW MONTHS MAYBE, THEN BLOW UP ON YOU. SPEND THE MONEY TO SWITCH OVER TO A MANUAL TRANNY FIRST.
TURBO BASIC FAQ:
Firstly, an exhaust manifold comes from an NA motor, so you'll need a turbo manifold. They come in many forms, Ram horn, top mount, log manifold, etc... Log manifold is by far the cheapest and it spools really quickly -- plus it's quite reliable if build right the first time. Here's what else you'll need for your car:
Turbocharger: Pick which size and trim turbo is gonna work best for your application and goals. A regular T3 turbo is usually good for 250WHP, a t3/t4 up to 400WHP, and a t4 400+ WHP... I'd recommend a ball-bearing garrett turbo, a nicely sized t3/t4 turbo, not too large or too small TRIM/AR size.
Downpipe: Again must be custom for your turbo/manifold choice. A flex pipe and o2 bung are nice to have while creating a downpipe -- although not necessary.
Wastegate: Choose a wastegate size (also what psi spring you'd like to run) according to application such as amount of air flow and psi from turbo.. This is if you have a turbo that's externally wastegate powered..
Intercooler: Choose either a FMIC (Front Mount InterCooler) or Side Mount Intercooler. FMIC is the only way to go really for efficient cooling..
Blow off valve: This is actually an optional (but very recommended part). Doesnt really matter which one you choose. Pick a sound you like. Some people like to use ebay or cheap BOV's, but if it fails, you can hurt your turbo -- so don't really cheap out.
Fuel Management: One of the most important parts on your turbocharged car. I would highly suggest running a programmable chipped ecu or standalone device. I'd suggest Hondata or Crome..
Fuel Pump : You will probably need an upgraded fuel pump to support the added fuel consumption. Can be either internal or external -- I recommended the Walbro 2550LPH hi pressure fuel pump kit from injected-performance.com on H-T's marketplace for sponsors
Injectors : To support added air induction, more fuel is need... hence bigger injectors. Buy size according to application.
Map Sensor: Stock maps can only read up to ~10.63 psi, if you plan to go higher upgrade to a 2bar or 3bar map sensor.
Intercooler Piping: You can buy a ic piping kit, but usally will always take some modification to fit your exact application.. I believe ebay has some kits that have flanges made for the greddy BOV's for around $150 shipped
Couplers/t-bolts: You will need silicone couplers to bind the two intercooler pipes together as well as t-bolts -- I don't recommend screw clamps for anything other than for your intake pipes for your custom Short Ram
Oil drain/feed lines: Every turbo needs oil, so you must buy an oil feed and drain line kit. Stainless Steel lines are HIGHLY recommended. Rubber lines will get hot and can/will burst.
Vacuum Manifold: Not required but recommended to help organize vacuum lines and allow for good vacuum sources. I'd use Golden Eagle's Vacuum manifold.
Gauges: although not required, it's highly recommend so you can keep some status of motor operation. boost/oil pressure highly recommended
Spark plugs: Although not required, turbo temps can get high, so i recommend you step down two steps colder in your spark plugs. Also copper too.. You need NGK BKR7E.. For SOHC it's: ZFR7E-11 spark plugs..
I have a bunch of helpful links I submitted to the Honda Civic/Del Sol (1992-2000) forum FAQ:
http://www.beesandgoats.com/bo....html
http://www.hondacivicforum.com/m_400322/tm.htm
HOW TO INSTALL THE TURBO AND EVERYTHING -- THE BEST TUTORIAL ON THE WEB: https://honda-tech.com/zerothread?id=1263795
I highly suggest reading a few!
Old Apr 23, 2008 | 12:40 PM
Frickr's Avatar
if i were you, i wouldnt waste the money on a turbo kit, till you get a manual tranny in your car. an automatic isnt going to be able to handle alot of power without the clutches slipping.
Old Apr 23, 2008 | 12:41 PM
ke98248's Avatar
Default Re: help me with my turbo setup (Frickr)
Pretty much already said that -- thanks for the confirmation
Old Apr 23, 2008 | 12:56 PM
Frickr's Avatar
Default Re: help me with my turbo setup (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Pretty much already said that -- thanks for the confirmation </TD></TR></TABLE>
you were just a little quicker at the draw
BoostdK
Oct 24, 2009 07:57 AM
1000kg88hb
Mar 12, 2007 01:01 PM
Supra
Jan 11, 2004 12:29 PM
stangkilla
Apr 30, 2002 03:04 PM
