My GSR is kicking out of VTEC...ECU problem???
Old Apr 23, 2008 | 12:17 PM
CarverGSR's Avatar
Default My GSR is kicking out of VTEC...ECU problem???
Well I just got this 89 Hatch recently and it has a B18C1 swap, and VTEC will sometimes engage under 5000RPMS or sometimes over 5000...and it will kick out of vtec whenever it wants, and the motor wont rev over 7000 RPMS...so i went and checked the code on the ecu and its a PW0 which is a JDM B16A ecu...would this possibly be my problem??? If so, would I have to get another ECU, or could I have this one chipped??
Old Apr 23, 2008 | 04:01 PM
zccr-xsi's Avatar
did u convert to obd1?
Old Apr 23, 2008 | 04:31 PM
Crx Jimmy's Avatar
Default Re: My GSR is kicking out of VTEC...ECU problem??? (CarverGSR)
are you sure its kicking out of vtec, with the ecu you have now your butterflies arent doing anything. maybe its doing something with them and your vtec isnt working at all. because 7000 is the cold/no vtec rev limit
Old Apr 24, 2008 | 12:19 PM
CarverGSR's Avatar
Default Re: My GSR is kicking out of VTEC...ECU problem??? (Crx Jimmy)
Im not sure if its converted or not...I have a obd0 ecu so id say its not, And ive also noticed that this ecu is supposed to have 2 02 sensors and I only have 1...So lets say I converted it to 2 O2's and got the ecu chipped would it run fine???...
Old Apr 24, 2008 | 01:56 PM
Hybridize's Avatar
No having 2 o2's will make it run right but wont effect your vtec.
I'll state an obvious question. How is your oil level and pressure? You should also check your vtec filter.
Again obvious stuff.
As far as only revving to 7k, is it hitting fuel cutoff at that point?
Old Apr 24, 2008 | 09:25 PM
mario_pic's Avatar
Default Re: My GSR is kicking out of VTEC...ECU problem??? (Hybridize)
if ur useing a converted po6 it will do that when there is a defective conponent
Old Apr 25, 2008 | 03:50 PM
soulpwr's Avatar
Default Re: My GSR is kicking out of VTEC...ECU problem??? (mario_pic)
Lets think really basic here. For Vtec to engage you need 3 things: You must reach operating temp, Mph over 35, and lastly....OIL PRESSURE
Old Apr 26, 2008 | 11:54 AM
CarverGSR's Avatar
Default Re: My GSR is kicking out of VTEC...ECU problem??? (soulpwr)
Oil pressure and temp are great...My oil level is perfect and doesnt leak or smoke at all...I drove it all night last night, and vtec will usually kick in at under 5000 and most of the time it will stay on until rev limit at 7000 rpms, but every once in a while it will kick out
Old Apr 26, 2008 | 12:16 PM
EF_ST@TUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarverGSR &raquo;</TD></TR><TR><TD CLASS="quote">Oil pressure and temp are great...My oil level is perfect and doesnt leak or smoke at all...I drove it all night last night, and vtec will usually kick in at under 5000 and most of the time it will stay on until rev limit at 7000 rpms, but every once in a while it will kick out</TD></TR></TABLE>
I had a similar problem a while back. Just run 4 new wires for VTEC to the ECU. probably a bad harness. OR go through with an OHM meter
Dave Brabant
Jun 28, 2018 01:17 PM
heflin94eg
Engine Management and Tuning
Dec 4, 2012 05:19 PM
DOHC-V-TEC-DA
Feb 3, 2006 06:03 PM
hatchbro
Oct 15, 2004 05:50 PM
