D16Z6 head mini me
Which OBD0 distributor will work on a D16Z6 and what timing belt do I need for a mini me setup on a 89 civic dx with a d15 motor?
Also will a D16Z6 intake manifold bolt up to a stock 89 d15 dx head? The DX motor is a two injector motor right now. What OBD0 distributor will I need to convert it to a four injector motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomdata »</TD></TR><TR><TD CLASS="quote">Which OBD0 distributor will work on a D16Z6 and what timing belt do I need for a mini me setup on a 89 civic dx with a d15 motor?
Also will a D16Z6 intake manifold bolt up to a stock 89 d15 dx head?</TD></TR></TABLE>
There is no OBD0 Dizzy that will work on a D16Z6 to my knowledge, You will need tore-wire the Dizzy to a OBD0 plug.
and yes, a Z6 manifold bolts right up to a D15 head, although you will have to convert the car to use MPFI instead of DPFI
What distributor will I need if I put a z6 intake on my d15 motor to convert to four injectors? a 88-91 civic si distributor? does it bolt up to the d15 head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc »</TD></TR><TR><TD CLASS="quote">
There is no OBD0 Dizzy that will work on a D16Z6 to my knowledge, You will need tore-wire the Dizzy to a OBD0 plug.</TD></TR></TABLE>
I know for a fact this won't work. The OBD0 and OBD1 dizzys have different internals and they are definitely not interchangeable. I need to figure out which OBD0 distributor will work.
Modified by Tomdata at 1:14 PM 4/23/2008
d15z, d16z6, distrib, distributor, distributors, distrubitor, fit, head, honda, internals, minimeconversion, obd, obd0, obdo, work
