Bad Thermostat??
Old Apr 22, 2008 | 10:47 PM
AZBB4's Avatar
Default Bad Thermostat??
Hey Everyone,
I recently purchased a 1994 Prelude Si with 150k miles. The engine seems to run pretty well, but I noticed that the temperature gauge does not move from the "cold" position (1 bar). I'm new to Preludes, but am used to the usual "middle" position with my prior Hondas (once up to running temp). I've done some research, and it seems like this might be the problem, but I just wanted to see if anyone else has had this same issue. Thanks for your time.
Old Apr 22, 2008 | 10:50 PM
dagle's Avatar
Default Re: Bad Thermostat?? (AZBB4)
does the temperature needle move at all? like when u start it, does it rise from below the C line to the C line? i noticed mine takes approx. 10 minutes to get to running temperature at idle.
Old Apr 22, 2008 | 10:57 PM
AZBB4's Avatar
Default Re: Bad Thermostat?? (dagle)
No, it begins at 1 bar temperature when started, and remains there for no matter how long I drive it (drove it for 1+ hour the other day, still remained at 1 bar temperature).
Old Apr 22, 2008 | 11:02 PM
dagle's Avatar
probably the needle itself inside the cluster.
Old Apr 22, 2008 | 11:06 PM
jlude90's Avatar
4th gens have digital readouts, so theres no needle
if you let it idle for a VERY long time, does it go up?
if not, it might be the sensor
Old Apr 22, 2008 | 11:08 PM
dagle's Avatar
Default Re: (jlude90)
that totally slipped my mind... yeah its the sensor if u got an EL cluster
Old Apr 23, 2008 | 01:03 PM
lude98SH's Avatar
Default Re: (dagle)
check the tempature on each side of the thermostat. If its just about always the same tempature then your thermostat is stuck open. It shouldnt be the same temp on both sides until the thermostat opens once the car is warm( i think its like 180 or 190 from factory but i could be wrong).
I had this same issue with my 95 accord and it was a stuck open thermostat. BTW having that stuck open will most likely kill your mpg.
Old Apr 23, 2008 | 09:01 PM
AZBB4's Avatar
Default Re: (lude98SH)
Cool, sounds good. I think I'm going to try the thermostat, mainly because I can't think of what else it can be. It's really weird, according to the temp gauge, the car never warms up, no matter how long I drive/idle. I'm going to change the thermostat, unless anyone can think of anything else.
Old Apr 24, 2008 | 09:56 AM
lude98SH's Avatar
Default Re: (AZBB4)
dont just try a thermostat. Throwing parts at something is an easy way to waste money. Do the tests and diag the problem, then replace what needs to be replaced.
jonathan13
16
Jul 31, 2009 04:27 PM
95teg_ls
Nov 12, 2008 01:06 PM
h22srb
Aug 30, 2007 04:26 PM
92hondalude
Jul 23, 2006 12:54 PM
soccmid1587
Jun 27, 2006 02:10 PM
