Civic With Gsr Swap Question Regarding attachment
Old Apr 22, 2008 | 08:57 PM
01typer1124's Avatar
Default Civic With Gsr Swap Question Regarding attachment
I have a 94 civic dx with my built gsr motor going in now when i ahd this gsr motor in the orignal car that i bought it in, it came with no power steering, when i install this gsr motor in the dx coupe i want to retain ym power steering, now my question is can i still use the d series power steering pump on the gsr motor and if so what brackets do i need, if not will i have to get a gsr power steering pump or will one of say a b18b motor work, and if the one of a ls motor works wat brackets will i need, the one the pump came off of or ones form a gsr motor, also the only thign in regards to my question i found by searching is using a pump from the gsr i would have to modify the line going to the pump or something, because i guess the line end that bolts to the pump is smaller or wat not on the civic line, thanks
Old Apr 23, 2008 | 04:48 AM
geebs's Avatar
Default Re: Civic With Gsr Swap Question Regarding attachment (01typer1124)
you need the brackets for the head you have.. so gsr brackets woulb be what your after.. as for the pump i think any b series ps pump will work with your ps line. im not sure tho.. its been awhile since i messed with eg stuff
OBDII Integra
Dec 3, 2009 07:20 AM
v0lcom27
Aug 31, 2005 06:17 PM
Wink1100
Feb 28, 2005 07:46 AM
kuelerz
Sep 24, 2002 10:16 AM
