b16 Rough idle after timing belt replacement??
Old Apr 22, 2008 | 04:32 PM
coilz's Avatar
Default b16 Rough idle after timing belt replacement??
Hi everyone..i replaced my timing belt and water pump a few weeks ago and since then my car has had a slight vibration at idle almost like a small miss..The cel is on. and i pulled code 54 crankshaft sensor. I checked the sensor today with an ohm meter and the sensor seems to be fine..
I reset my timing to factory specs, and replaced my cap, rotor, plugs, and fuel filter, but its still on going.. The car runs fine otherwise.
What could it be?
Thanks Greg
Old Apr 22, 2008 | 05:56 PM
slacks's Avatar
Default Re: b16 Rough idle after timing belt replacement?? (coilz)
i would check to see that the crank pulley was at TDD, cams were pointing up, and the spark plugs in the right firing order.
Old Apr 22, 2008 | 07:18 PM
Former User's Avatar
You may also want to bleed the cooling system of possible trapped air, although this would not explain the CKF sensor CEL code.
Old Apr 23, 2008 | 07:32 AM
mmafighter130's Avatar
hey man definitely timing belt is off a tooth is its throwing that code.
Old Apr 23, 2008 | 07:49 AM
b16a3delsol's Avatar
check the crank pulley to make sure the pickup isnt damaged for the ckp sensor.
Old Apr 23, 2008 | 03:42 PM
coilz's Avatar
Default Re: b16 Rough idle after timing belt replacement?? (b16a3delsol)
thanks you guys all check these tomorrow...and let you know
Greg
Old Apr 23, 2008 | 03:51 PM
TODAwhore's Avatar
i know the crank sensor doesnt like getting wet..and you did the water pump, did you move it out of the way before pulling the pump off?
Mustang72
Honda Civic (2001 - 2005)
Dec 1, 2014 08:04 PM
Gunnar72
Jul 5, 2014 06:32 PM
vegasEGcoopy
Jun 13, 2007 08:28 PM
padraf
Jul 14, 2004 02:49 PM
red civic standard
Jul 14, 2002 07:25 PM
