Suspension & Brakes Theory, alignment, spring rates....
tein s tech
Old Apr 22, 2008 | 03:32 PM
mmboost21's Avatar
Default tein s tech
I just ordered some tein s tech springs for my 2000 teg....u guys think i will need a camber kit? If so...would it just be a regular one thats not adjustable?
Old Apr 22, 2008 | 08:00 PM
EK_B's Avatar
You won't need it, you'll need an alignment though.
Old Apr 23, 2008 | 06:18 AM
mmboost21's Avatar
ok thanks...anyone else?
Old Apr 23, 2008 | 06:55 AM
EK_B's Avatar
Default Re: (mmboost21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmboost21 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks...anyone else? </TD></TR></TABLE>
Okay, sure! I'll chime in! <U> YOU DON'T NEED A [freak]ING CAMBER KIT IF YOU ARE WORRIED ABOUT TIRE WEAR. </U>
An alignment will fix your toe, toe is the one that eats tires more.
Old Apr 23, 2008 | 09:41 AM
mmboost21's Avatar
hey chill out man im just trying to get input..the more the better which i do appreciate yours believe me....but yea i dont want tire wear...in reference to performance,would a camber kit really improve it after lowering it?
Old Apr 23, 2008 | 02:15 PM
EK_B's Avatar
Okay, ossry, I think you're in a learning process right? Here it is, negative camber is said to give better handling, when you drop your car, you get negative camber. See where I'm heading? So unless you want even more negative camber, you won't need a camber kit.
Old Apr 24, 2008 | 09:56 AM
mmboost21's Avatar
ok thanks...appreciate it
hondapunkrock
Jul 21, 2008 07:34 AM
gurlracer_camille
10
Feb 19, 2007 07:47 PM
RicedREX
Feb 28, 2004 07:19 AM
tgrace
Jan 15, 2004 03:42 PM
FlaN.
Nov 5, 2003 11:39 AM
