Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Interior removal allowed in SCCA SM2??
Old Jul 12, 2002 | 08:11 AM
DIY_Racing's Avatar
Default Interior removal allowed in SCCA SM2??
the 2002 SCCA rule book is rather vague as to the legality of interior removal in the Street Modified 2 class. Any help?
Old Jul 12, 2002 | 08:13 AM
Drew M's Avatar
New User
Default Re: Interior removal allowed in SCCA SM2?? (DIY_Racing)
As far as I know it IS NOT legal in front of the rearmost seats. Anything behind is ok however.
Old Jul 12, 2002 | 08:39 AM
DIY_Racing's Avatar
Default Re: Interior removal allowed in SCCA SM2?? (Drew M)
So the headliner has to stay? I need more helmet room... lol
Old Jul 12, 2002 | 08:44 AM
PseudoRealityX's Avatar
correct, headliner has to stay. Can you lower your seat further?
Old Jul 12, 2002 | 08:53 AM
RineRacing's Avatar
If you need more helmet room, install a racing seat with side mount brackets.
Old Jul 12, 2002 | 09:03 AM
CivicSiRacer's Avatar
Default Re: Interior removal allowed in SCCA SM2?? (Geratol)
Full interior is needed for SM/SM2. You can cut away to install a roll cage/bar.
Do you have a harness? I recommend that since when I pull down hard on my straps it shrinks me about 1-2". My helmet brushes the roofline without my harness on.
You can also do aftermarket seats in SM/SM2 - if that helps.
Old Jul 12, 2002 | 03:05 PM
XrcR6's Avatar
You may as well apply the Stock class rules for SM2 interior removal. Just the stuff that can't be securely fastened down (ex. loose covers/panels in the hatch/trunk, etc.) can be removed. The parcel shelf, the plastic cover over the spare tire, and the spare tire in a CRX.
The only reason why SM cars look "stripped" is because they get to remove the rear seats... For example, every M3 at the Nat. Tour looked like bare painted metal from behind the front seats to the trunk.
I don't think its possible to even get near the 1500lbs. min. weight. that a <3.0ltr. fwd SM2 is allowed. Believe me I loose sleep over this...
BB6-213
Welding / Fabrication
May 8, 2007 04:50 PM
comptechgsr
Feb 2, 2003 07:46 PM
Halo
Jul 17, 2001 04:20 PM
Cyber ITR
Apr 24, 2001 12:53 AM
