Help Fixing Carbon Fiber
Old Apr 22, 2008 | 08:30 AM
atmospheric SOUL's Avatar
Default Help Fixing Carbon Fiber
I just got a carbon fiber hood, but it has major fades and wear. Does Anyone know how to fix it ? I searched it up and it said Wetsanding it and buffing works ? can someone give me some techniques or solutions ? TIA.
Old Apr 22, 2008 | 11:26 PM
Dinosource's Avatar
Default Re: Help Fixing Carbon Fiber (atmospheric SOUL)
Wetsanding works wonders on most CF parts. They come from the factory with clear on them, so try going over it a small bit with 1500 grit first, and then buffing it to a finish with compound and a PC. I hope you have some experience wetsanding. It's pretty easy to burn through older clearcoat.
Modified by Dinosource at 12:45 AM 4/23/2008
Old Apr 23, 2008 | 04:18 AM
RoadRage212's Avatar
http://www.topoftheline.com/32ozheavcutp.html
^I used this stuff to do a used JDM c/f hood that came over here on a Preulude Type S. It looked like hell. There was a big layer of yellow oxidation covering it and you couldn't see a reflection even if you got really close to it. The hood itself was cheap and flimsy so it was a pain to buff out. To make a long story short, I didn't even have to sand it down. It didn't come out completely perfect, but it looked new compared to what it was and you could see it shine from a mile away.
I've recommended it to several people and some have had the same luck, some haven't. All I know is that its freakin' awesome. Granted, it took me almost an hour and a half of straight buffing on just that one hood to get it to look right, but eventually it came out. I also had to re-buff a few small spots that popped back up but after that it was awesome. Buy it at your own risk but I'll never be without it I'll tell you that much.
Old Apr 23, 2008 | 10:28 PM
nsone's Avatar
I've dealt with at least 6 CF hoods that are faded.
major fades and wear only means the clear coat is going revealing the resin.
Re clear it.
IT's an easy task for a shop or individual who can paint.
Ive charged 75 buks for material and my time.
Wetsanding and buffing will only take more of the coating away.
Old Apr 24, 2008 | 07:06 PM
iam7head's Avatar
Default Re: Help Fixing Carbon Fiber (Dinosource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dinosource &raquo;</TD></TR><TR><TD CLASS="quote">Wetsanding works wonders on most CF parts. They come from the factory with clear on them, so try going over it a small bit with 1500 grit first, and then buffing it to a finish with compound and a PC. I hope you have some experience wetsanding. It's pretty easy to burn through older clearcoat.
Modified by Dinosource at 12:45 AM 4/23/2008</TD></TR></TABLE>
90 percent of the chinese low quality junk knock off are gel coat only.
wrong info batman
Old Apr 24, 2008 | 09:40 PM
Default Re: Help Fixing Carbon Fiber (nsone)
so what are you recommending nsone ?
btw, i bought a buffer, 1000 grit sandpaper, and Zymol Wax. Is this all i need ? i`ll post pictures soon.
Old Apr 24, 2008 | 10:15 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
What brand is the hood?
Old Apr 25, 2008 | 10:12 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atmospheric SOUL &raquo;</TD></TR><TR><TD CLASS="quote">so what are you recommending nsone ?
btw, i bought a buffer, 1000 grit sandpaper, and Zymol Wax. Is this all i need ? i`ll post pictures soon.</TD></TR></TABLE>
stop scamming people?
Old Apr 25, 2008 | 11:19 AM
Default Re: Help Fixing Carbon Fiber (iam7head)
i don`t get it, how is this scamming someone ?
Modified by atmospheric SOUL at 3:53 PM 4/25/2008
Old Apr 29, 2008 | 05:10 AM
b18b1ef8's Avatar
wet sand it with like 1500 sand paper until there is no more shiny spots
use extra cut compund with a wool pad to buff it and then use final glaze with a foam pad to finish it
u should also wax it after its done
SwampThing
Sep 6, 2005 02:51 PM
WhitEdRift
Welding / Fabrication
Aug 5, 2005 07:55 AM
crazy_ham
Jun 20, 2004 04:03 PM
speed
Mar 6, 2003 11:48 PM
