throttle response problems??
Old Apr 21, 2008 | 10:17 PM
prolifik22's Avatar
Default throttle response problems??
well i have put a mini me swap in an ej1 and im have no throttle response what so ever...i have tried to replace the throttle body ---not it...i have replaced the ecu--not it...i have tried to retime it over and over and still no fix...
to be honest i never ran into this problem and it has me stumped.
so if anyone can posibaly help i would appreciate it..
thnx for lookin
Old Apr 21, 2008 | 10:40 PM
prolifik22's Avatar
also its a d15b7 with a z6 head...anythin else lmk thnx
Old Apr 21, 2008 | 11:38 PM
ddd4114's Avatar
Default Re: (prolifik22)
Did you remember to use a y7/y8 cam gear (or adjustable one)?
Old Apr 22, 2008 | 12:06 AM
prolifik22's Avatar
well y wld u use a diffrent cam gear?? and also whats the diffrence juz a question cuz i have a turbo build and it dnt have an adjustable one or nuttin and it ran good..yea i kno i said ran i tore it apart for a build up
Old Apr 22, 2008 | 12:11 AM
ddd4114's Avatar
When you mate a z6 head to a b7 block, the mechanical timing will be off by 1/2 tooth. You will need a y7/y8 or adjustable gear to correct for the offset.
Old Apr 22, 2008 | 12:22 AM
prolifik22's Avatar
thats sounds reasonable i actually have a y8 so thnx for lettin me kno that..also tho it bein a tooth or 1/2 that shld keep it from not havin throotle reponse?
Old Apr 22, 2008 | 12:33 AM
ddd4114's Avatar
Yes, 1/2 tooth can make a noticeable difference.
Old Apr 22, 2008 | 01:06 AM
prolifik22's Avatar
yea it can make a diffrence but not to have no throttle at all
Old Apr 22, 2008 | 11:14 AM
prolifik22's Avatar
anyone ran into this ?? help me out
Old Apr 22, 2008 | 11:54 AM
ddd4114's Avatar
What do you mean by "not to have no throttle at all"?
If you type more clearly, you will get more help.
Old Apr 22, 2008 | 06:09 PM
prolifik22's Avatar
like it can make a diffrence if the timing is off but that will not keep it from havin dead throttle
and what i mean my dead throttle means the car will turn on and idle but when u give it gas it has no throttle response what so ever...
Old Apr 22, 2008 | 06:10 PM
ddd4114's Avatar
Any CEL's?
Old Apr 22, 2008 | 06:14 PM
prolifik22's Avatar
nope juz the v-tec to to the pressure sensor bein messed up
Old Apr 22, 2008 | 08:23 PM
prolifik22's Avatar
well i was thinkin bout doin a valve lash check but dnt kno yet havent found a good enough diy or anythin related to it..lmk if anyone can help
ATLien6
Jun 2, 2012 01:53 PM
ek-tuner
Apr 4, 2008 10:16 AM
Civicman86
Jul 10, 2006 08:08 AM
spun Vtec
Jan 31, 2003 08:42 AM
