throttle response problems??
well i have put a mini me swap in an ej1 and im have no throttle response what so ever...i have tried to replace the throttle body ---not it...i have replaced the ecu--not it...i have tried to retime it over and over and still no fix...
to be honest i never ran into this problem and it has me stumped.
so if anyone can posibaly help i would appreciate it..
thnx for lookin
thnx for lookin
well y wld u use a diffrent cam gear?? and also whats the diffrence juz a question cuz i have a turbo build and it dnt have an adjustable one or nuttin and it ran good..yea i kno i said ran i tore it apart for a build up
Re: (prolifik22)
When you mate a z6 head to a b7 block, the mechanical timing will be off by 1/2 tooth. You will need a y7/y8 or adjustable gear to correct for the offset.
thats sounds reasonable i actually have a y8 so thnx for lettin me kno that..also tho it bein a tooth or 1/2 that shld keep it from not havin throotle reponse?
like it can make a diffrence if the timing is off but that will not keep it from havin dead throttle
and what i mean my dead throttle means the car will turn on and idle but when u give it gas it has no throttle response what so ever...
well i was thinkin bout doin a valve lash check but dnt kno yet havent found a good enough diy or anythin related to it..lmk if anyone can help
ATLien6
06-02-2012 01:53 PM
Civicman86
07-10-2006 08:08 AM
