What are the differences between alternators(obd0-obd2)
Old Apr 21, 2008 | 07:18 PM
NugKaLj's Avatar
Default What are the differences between alternators(obd0-obd2)
i was just wondering if i could put an obd1 alternator on my obd0 b16a because i currently have one on me, if not it would be nice to know the differences between them.
Old Apr 21, 2008 | 10:36 PM
NugKaLj's Avatar
Default Re: What are the differences between alternators(obd0-obd2) (NugKaLj)
anyone?
Old Apr 22, 2008 | 12:41 AM
Zdyned's Avatar
just the wires i beleive sir, my buddy coverted his obd2 to an obd0 so i know i t can be done, im just not sure how..
Old Apr 22, 2008 | 01:56 AM
dr_latino999's Avatar
Default Re: What are the differences between alternators(obd0-obd2) (Zdyned)
The connections to the harness are the same between OBD-0 and OBD-1 but the pulleys may be different; they are at least between OBD-0/1 D-Series.
Old Apr 22, 2008 | 10:08 AM
NugKaLj's Avatar
Default Re: What are the differences between alternators(obd0-obd2) (dr_latino999)
worddd... so are there any differences between b-series and d-series then? thanks for all the info much appreciated
Old Apr 22, 2008 | 01:13 PM
da6jdmteg's Avatar
obd-o and 1 share alternator. only b for b. i wouldnt do a d series on a b. different ribbs on the pulley.
Old Apr 22, 2008 | 02:44 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NugKaLj &raquo;</TD></TR><TR><TD CLASS="quote">i was just wondering if i could put an obd1 alternator on my obd0 b16a because i currently have one on me, if not it would be nice to know the differences between them.</TD></TR></TABLE>
yes obd0 and obd1 alternators are the same, obd2 will mount up fine but have a different plug, they also have a larger shaft that the pulley bolts on to
Old Apr 22, 2008 | 04:56 PM
grog's Avatar
Default Re: What are the differences between alternators(obd0-obd2) (Crx Jimmy)
somebody did a write up on how to convert alternators from obd0-obd1 (or vice versa, I forget) if you search around, sorry I could'nt find it but its out there.
GL
Old Apr 22, 2008 | 10:06 PM
mario_pic's Avatar
Default Re: What are the differences between alternators(obd0-obd2) (grog)
it depends some obd2 alternators have only 3 wires thoes cant be converted for instance i got a 99 si d16y8 runing in my 91 civic useing a 92 civic alternator the belts match the y8 pully and the plug matches the 91 civic plug so its a simple task if u want a obd1 to work on a obd0 wireing wise is the same but the pully is short one tooth so u can just swap the pullys if u got the time
Old Apr 23, 2008 | 04:22 PM
NugKaLj's Avatar
Default Re: What are the differences between alternators(obd0-obd2) (mario_pic)
koo i'll try it out thanx
alexm
May 10, 2009 09:24 PM
guymosiris
May 1, 2007 11:06 PM
-Justin-
Feb 8, 2004 08:07 PM
4crx4me
Jan 14, 2004 04:32 PM
