Cylinder head specs needed
Workingon simulating a b18C engine in a new piece of software i've obtained, unfortuanatly, the software comes with many short blocks and head combinations for pushrod motors, a bit more info is required to get said software to work on OHC layouts.
Anyway, i have a decent idea of what some of these values should be, but, more accurate input data should theoretically make the output of the software a bit more accurate. So, if anyone can toss out some numbers for the following variables (B16A head or GSR, i don't care), i'd appreaciate it.
Port length
Average port diameter
intake manifold runner diameter @ head
intake manifold runner length
Plenum Volume
Also, if anyone has any flowbench data from a stock/midly ported/full ported head, would be nice.
D
Port length
Plenum Volume
D
So, I just happen to have my helms at work today (studying up on clutch replacement
). You still need this chit? I have the '95 book, I'll look it up for ya.
[edit] hmm on second thought is that suff even in the Helms??
[Modified by MrBite, 1:30 PM 7/12/2002]
). You still need this chit? I have the '95 book, I'll look it up for ya.[edit] hmm on second thought is that suff even in the Helms??
D'oh! There are blank lines for the type ARRRRR in this Speed WC tech sheet...
http://www.speedvisionwc.com/competi...-integra-r.pdf
no luck otherwise though
dayaftertomorrow
21
Mar 7, 2006 11:39 AM
giooooo
Sep 21, 2002 12:53 PM
