Super Glue Removal. Help please.
Old Apr 21, 2008 | 03:44 PM
treeboxgrass's Avatar
Default Super Glue Removal. Help please.
Is there any way to get superglue off without damaging the paint?
There is superglue all over the hood, trunk, and side panels of my car. Someone probably thought it would be a good prank, but I haven't the slightest idea how to get it off w/o damaging the paint.
Old Apr 21, 2008 | 04:29 PM
GuNnErGoD's Avatar
Default Re: Super Glue Removal. Help please. (treeboxgrass)
I've never had to remove super glue before.. maybe someone else can chime in?
If I was going to make a suggestion, I would try a combination of a heat gun and a rag soaked in lacquer thinner. See what you can do with the heat gun first because the lacquer thinner is going to dry up and scratch the paint. It's not a big deal if you have the tools to fix it but if you don't then you're making more work for yourself.
Anyone else?
Old Apr 21, 2008 | 09:55 PM
accent0002's Avatar
Default Re: Super Glue Removal. Help please. (GuNnErGoD)
you could try finger nail polish remover if it has acetone in it or you could just try straight acetone...http://www.supergluecorp.com/removingsuperglue.html
Old Apr 24, 2008 | 03:18 PM
Thanks for the input! I might try this out sometime. Hopefully, I don't screw anything up...
Old Apr 24, 2008 | 06:29 PM
kiddcarbuff's Avatar
i would try goof off or goo gone to be honest, test it in an inconspicous spot to see if it takes the paint. you can also try the heat gun and wax and grease remover
94ej1coupe206
14
Nov 25, 2016 11:57 AM
bluenc-87
Paint and Body
Jul 19, 2009 06:22 PM
HamiltonRex
16
Aug 9, 2006 05:19 PM
Pullig
Jan 15, 2005 12:32 AM
89DXDann
May 25, 2004 10:41 PM
