EK Engine
Old Apr 21, 2008 | 12:35 PM
CivicEK321's Avatar
Default EK Engine
Hey Everybody! Just a quick question. What type of Engine comes in an Ek (stock of course)?
Just wonderin'. Ask questions about whatever as needed.
Old Apr 21, 2008 | 12:37 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: EK Engine (CivicEK321)
i know some come with d16y7
Old Apr 21, 2008 | 12:58 PM
rarrior23's Avatar
Mine came with the SOHC VTEC D16Y8
Old Apr 21, 2008 | 01:00 PM
DCSportEJ1Civic's Avatar
Default Re: EK Engine (Dead CIVIC)
depends on which car your talking about. either the d16y7, d16y8, or b16a2 as far as i know.
Old Apr 21, 2008 | 02:37 PM
'96typeR's Avatar
y7
Old Apr 21, 2008 | 04:18 PM
jday1's Avatar
Default Re: EK Engine ('96typeR)
i second the y7
Old Apr 21, 2008 | 04:34 PM
SpeedoKing's Avatar
Default Re: EK Engine (jday1)
the hatch came in y7 if you are talking about the sedan or coupe then the dx and lx were y7 and the ex was y8. if you are talking about the type-r then it was a b16b
Old Apr 21, 2008 | 05:05 PM
-JAWSHUA-'s Avatar
Default Re: EK Engine (SpeedoKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedoKing &raquo;</TD></TR><TR><TD CLASS="quote">the hatch came in y7 if you are talking about the sedan or coupe then the dx and lx were y7 and the ex was y8. if you are talking about the type-r then it was a b16b </TD></TR></TABLE>
way to clear things up.
Old Apr 21, 2008 | 05:17 PM
Dead CIVIC's Avatar
Veteran: Army
good
Old Apr 21, 2008 | 06:49 PM
ok
usdm 96-00 d16y7 sohc non vtec
usdm 96-00 ex d16y8 sohc vtec
usdm 99-00 si b16a2 dohc vtec
im pretty sure the jdm type r was the b16b
the canadian civic were a little different
the EDM's even came with d14's and d13's i believe.
NOFX would be able to tell you for sure. she should chime in soon.
Old Apr 21, 2008 | 09:38 PM
NOFX's Avatar
H-T White Ops
Well, it really depends on what cars you're talking about. When you say "EK", I'll assume that you're talking about 1996-2000 Civics.
See people, this is what I mean when I say that if you want to use chassis codes, to please know what they mean or else just use the trim, etc. to identify the vehicle.
So, here's a quick break down of some of the cars and the engines. I'll also include chassis codes to help you learn about real chassis codes.
I'm only going to list the US chassis first of, since you're probably in the United States. If you need information from another country, tell me.
There are no EK chassis cars in the US. You'll see that for the 6th gen Civics, chassis codes usually match to certain engines or certain engine types. For example, EJ6s would all have 1.6L SOHC non-VTEC engines, though the engine code is probably different in other countries.
<FONT SIZE="3">COUPES</FONT>
1996-2000 Civic DX coupe
Chassis Code: EJ6
Engine Code: D16Y7
Horsepower: 106 hp @ 6200 rpm
Torque: 103 lb-ft @ 4600 rpm
Compression Ratio: 9.4:1
1996-2000 Civic EX coupe
Chassis Code: EJ8
Engine Code: D16Y8
Horsepower: 127 hp @ 6600 rpm
Torque: 107 lb-ft @ 5500 rpm
Compression Ratio: 9.6:1
1996-2000 Civic HX coupe
Chassis Code: EJ7
Engine Code: D16Y5
Horsepower: 115 hp @ 6200 rpm
Torque: 104 lb-ft @ 5400 rpm
1999-2000 Civic Si coupe
Chassis Code: EM1
Engine Code: B16A2
Horsepower: 160 hp @ 7600 rpm
Torque: 111 lb-ft @ 7000 rpm
Compression Ratio: 10.2:1
<FONT SIZE="3">HATCHES</FONT>
1996-2000 Civic CX hatch
Chassis Code: EJ6
Engine Code: D16Y7
1996-2000 Civic DX hatch
Chassis Code: EJ6
Engine Code: D16Y7
<FONT SIZE="3">SEDANS</FONT>
1996-2000 Civic DX sedan
Chassis Code: EJ6
Engine Code: D16Y7
1999-2000 Civic DX-V (aka SE or VP) sedan
Chassis Code: EJ6
Engine Code: D16Y7
1996-2000 Civic EX sedan
Chassis Code: EJ8
Engine Code: D16Y8
1998-2000 Civic GX sedan
Chassis Code: EN1
Engine Code: D16B5
Horsepower: ??? hp @ ???? rpm
Torque: ??? lb-ft @ ???? rpm
Compression Ratio: 12.5:1
1996-2000 Civic LX sedan
Chassis Code: EJ6
Engine Code: D16Y7
You could have found this information in this thread by the way:
6G Civic Trim Difference
Other country's information can be found in this thread, though it's not as informative as my other thread:
The Ultimate Honda Chassis Code List
All 1996-2000 Civic chassis codes are as follows (this will help you find the info in the thread I just linked):
EJ6 (1.6L SOHC non-VTEC 2/3/4 door)
EJ7 (1.6L SOHC VTEC-E 2 door)
EJ8 (1.6L SOHC VTEC 2/4 door)
EJ9 (1.4L SOHC non-VTEC 3/4 door)
EK1 (1.6L SOHC VTEC-E 3/4 door)
EK2 (1.3L SOHC non-VTEC? 3/3 door)
EK3 (1.5L SOHC VTEC 3/4 door)
EK4 (1.6L DOHC VTEC 3/4 door)
EK5 (1.6L SOHC ?? 4 door 4WD)
EK6 (??L SOHC ?? 3 door)
EK7 (??L SOHC ?? 3 door)
EK8 (1.6L SOHC ?? 4 door 4WD)
EK9 (1.6L DOHC VTEC 3 door)
EM1 (1.6L DOHC VTEC 2 door)
EN1 (1.6L SOHC VTEC CNG 4 door)
Modified by NOFX at 10:49 PM 4/21/2008
Old Apr 21, 2008 | 09:41 PM
v!taminb16's Avatar
Default Re: EK Engine (NOFX)
it all depend's on what year and model but nofx know's his stuff your better of listening to him
Old Apr 21, 2008 | 09:51 PM
watsvtecEK's Avatar
Default Re: EK Engine (v!taminb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v!taminb16 &raquo;</TD></TR><TR><TD CLASS="quote">it all depend's on what year and model but nofx know's his stuff your better of listening to him </TD></TR></TABLE>
lol
Old Apr 21, 2008 | 09:56 PM
NOFX's Avatar
H-T White Ops
Default Re: EK Engine (DCSportEJ1Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic &raquo;</TD></TR><TR><TD CLASS="quote">ok
NOFX would be able to tell you for sure. she should chime in soon. </TD></TR></TABLE>
The Canadian cars for the most part are the same, but the trims use different names. It's kind of confusing.
US EX = Canadian Si
US Si = Canadian SiR
For the most part the CX, DX, etc are the same... at least engine choice-wise.
At the bottom of the trim differences post I linked above there's a key to the engines and chassis codes for US versus Canadian trims.
Oh, and the Civic Type R only came in Japan. It was shipped to Europe later because it's apparently cheaper for them to ship JDM vehicles there, but that's why they're so plentiful there too.
Old Apr 21, 2008 | 11:04 PM
x0!'s Avatar
x0!
vitaminb16, nofx is a she not a he.
she definately knows her stuff
xquiksilvazx
13
Apr 11, 2007 11:45 PM
NHB
Apr 3, 2007 08:23 PM
EFstyle
Jul 19, 2006 07:07 PM
lswift
Aug 9, 2004 05:53 PM
Rhythm Racer
10
Oct 1, 2003 08:35 PM
