Brake Rotors
Hi,
I recently bought a rear disc conversion kit for my car off a Integra. And I was looking into buying some new rotors all around, but Im a bit confused as to what rotors I need. Some of them say for ABS, and some say for Non-ABS, what would be the diff, thewy are both just metal discs? And since the rear discs are from a Integra, are they a different rotor?
I was looking into getting these: WIll they fit?
http://cgi.ebay.ca/Honda-Civic...wItem
Thanks
Matt
Thanks
Matt
You still have Civic brakes up front? You need Civic rotors up front. You have Integra brakes in the rear? You need Integra rotors in the back. Does your car have ABS? If so, you'll definitely have to make sure you hook up your wheel speed sensors in the back. The rotors (whether ABS or non) should be the same. The discs are a different rotor than the EG Civic Si (I'm pretty sure) so you'll just have to make sure to get Integra stuff out back.
Don't get those rotors. Do you track it? Is that why you want the cross-drilled and slotted? If it's just a street car, go with Brembo blanks and get a good set of pads, like Hawk or Performance Friction. Then get a 15'16" master cylinder and a 40/40 prop valve and you'll be ready to put flat spots on your tires!
dont get cross drilled/slotted rotors. complete waste of money
goto autozone and buy some blank rotors. they come with a lifetime waranty.
then get some good pads. thats all you need
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Abius »</TD></TR><TR><TD CLASS="quote">Alright, thanks guys, so infront I need Civic DX, and if I get a rear disc conversion from an integra I need integra rotors right?</TD></TR></TABLE>
If you have rear disc brakes it does not matter since the rear rotors are the same size from the 90-91 CRX, to the Integras and 99-00 Civic Si. But if it makes it easier for you then yes order the Integra rear rotors. ABS has nothing to do with the rotor itself.
If you have stock Civic DX front brakes, then to make it easier for you just get stock Civic DX rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoo my gosh »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 »</TD></TR><TR><TD CLASS="quote">get a good set of pads, like Hawk</TD></TR></TABLE>
x2 good stuff. and just get the integra rotors
dynimitejack
11
Aug 9, 2008 11:32 AM
youngkow
Nov 14, 2002 06:16 PM
