Weird Check light
Ok i was driving to work this morning and the light poped on. The car bogged down for a second then back to normal then every now and then it boged down then normal. Whats weired is i pulled the code and the light came on. But there was no flash or anything. It just stays on, no flash or anything at all. My setup is b16 boosted on a socketed p28 running the osterich for tunning. I looked at the list for codes, how would i know if the ecu is bad? Any inputs would be well appreciated.
Thanks
Thanks
Your check engine light will not flash UNLESS you have jumped the two pins/wires at the diagnostic plug near the ECU.
EDIT: Oh, after you've jumped the pins, if the CEL doesn't flash and stays solid, then and only then does that indicated an ECU problem.
rudyndrew
Jan 5, 2011 05:32 PM
Project_EK
Aug 13, 2005 04:08 PM
