Port and polish, how long do they last?
Old Apr 20, 2008 | 10:39 PM
Prudz_lude's Avatar
Default Port and polish, how long do they last?
I am just curious how long they are actually effective. I know you can get some good gains from them but how long do those gains actually last for? if you look inside alot of intake manifolds they get covered in oil and blow by. Same goes with the intake and exhaust runners of the head. Once they are covered the port and polish is kind of useless unless everything is unassembled and recleaned.
some insight into this would be nice. Thanks you.
Old Apr 21, 2008 | 05:34 AM
Acidcrakker's Avatar
Default Re: Port and polish, how long do they last? (Prudz_lude)
Correct me If Im wrong but a port and polish consists of making the IM bigger. ANd then its polished on top of it
Old Apr 21, 2008 | 06:54 AM
H22Luda720's Avatar
Default Re: Port and polish, how long do they last? (Acidcrakker)
I think it would be harder for build-up to stick to a polished surface than factory cast
Port matching would not be affected by build up
I think power loss(if any) would be spread out over such a long period it would not be noticeable. A dirty port&polish job would probly still make better numbers than factory IMO
Old Apr 21, 2008 | 08:02 AM
Prudz_lude's Avatar
Default Re: Port and polish, how long do they last? (H22Luda720)
Acidcrakker, what you are thinking of is called port matching. You ink the IM to the size of your head after a port and polish has been done to the head. You then file away the un inked areas to make a flawless transition between the head and IM.
H22luda720, that makes a bit of sense. I guess my question is more, how long does it take for blow by to happen in the IM and runners? the second you have blow by sticking to the head and IM the air is not really benefitting from the P&P because it is now travelling along uneven gunk instead of the polished metal.
Old Apr 21, 2008 | 08:15 AM
H22Luda720's Avatar
There is to many variables across different engines, builds, and tunes to accurately predict how long it takes for build-up to occur.
I don't think the possibility of build up affecting flow is enough to outweigh the benefits of a good/proper Port & Polish.
Old Apr 21, 2008 | 08:40 AM
Prudz_lude's Avatar
hmmm ok. I was just curious so i thought i would post my question. Thanks for the reply. I'll just get a catch can to try and prolong the inevitable.
Old Apr 21, 2008 | 09:37 AM
98vtec's Avatar
moderator emeritus
port and polish has to do with the head. There isn't a generic port and polish. You send the head to the machinist and they reshape the port runners to flow better and cut the valve seats at multiple angles so that the flow rate increases...or at least thats the idea behind it.
If you keep your engine maintained you wont have a problem with carbon build up.
Old Apr 21, 2008 | 11:22 AM
mgags7's Avatar
Valve jobs do wear out over time. Ask any porter and they'll give you their own estimate on how long the valve job will "last".
You won't so much not run right as you will just start to lose some CFM as the cuts wear.
That is the only aspect of a head job I'd worry about wear and tear on.
Old Apr 21, 2008 | 12:11 PM
Prudz_lude's Avatar
Default Re: (mgags7)
Thanks guys.
pomansouth01
May 20, 2007 03:36 PM
boostnubII
10
Dec 10, 2006 04:11 PM
b18sihatch
Jul 23, 2006 02:10 PM
6snoop6
Feb 2, 2004 05:07 PM
