few questions after converted to obd1
Old Apr 20, 2008 | 10:15 PM
tacorunner87's Avatar
Default few questions after converted to obd1
Well when the car starts the tach jumps all the way to 8K but hear the motor rev up.
When cold car idles about 2k rpm
i dont see a check engine light but once the 2 wires touch to read codes i get a code 9. i switched wires around on the dizzy harness and check engine light pops instantly. normal?
I dont have the obd1 injectors in still running a resistor box will it run better if i switch out the injectors?
timing, go to set the timing and with th dizzy all the was maxed out the timing is still about 1/8' off kinda weird i thought
Old Apr 21, 2008 | 12:40 PM
Default Re: few questions after converted to obd1 (tacorunner87)
anyone?
dohc15
Jan 10, 2012 11:17 AM
thatHEMIguy
28
Nov 28, 2010 08:53 PM
bigodub93
Jan 11, 2008 05:30 PM
hatchinprogress
16
Jan 7, 2005 09:09 AM
