vtec kick
Old Apr 20, 2008 | 09:41 PM
maal15's Avatar
Default vtec kick
when does the vtec usually kick in i get different rpms. some people say 3500 or so and some say 5500
Old Apr 20, 2008 | 09:44 PM
matt_fa5's Avatar
what car? please be specific?
Old Apr 20, 2008 | 09:47 PM
Ep1dem1c's Avatar
Default Re: vtec kick (maal15)
obviously if he cant tell then it is a SOHC....
but who cares if you cant hear it or feel it then whats the difference?
Old Apr 20, 2008 | 10:08 PM
baller status's Avatar
VTEC is not controlled by RPM's alone. It's dependent on load and throttle % as well. ALL conditions must be met. If you're at part throttle and medium load, eventhough you're past the VTEC crossover point, you'll actually make more power by not going into VTEC. And if your foot isn't pushing the pedal hard you obviously don't want VTEC anyway.
Old Apr 20, 2008 | 10:25 PM
mizzoEG's Avatar
What motor is it? Not all VTAK's "kick" at the same specs. Gotta be more specific.
Old Apr 21, 2008 | 04:29 PM
maal15's Avatar
sorry its the sohc y8
Old Apr 21, 2008 | 04:37 PM
.illwhitecoupe.'s Avatar
Default Re: (maal15)
I have the same motor mine comes in at about 5k but it doesnt give much of a "kick"
Old Apr 21, 2008 | 04:45 PM
gamby's Avatar
I'd like to say it's not 'til around 6k. It's way up there.
Lowering the crossover point doesn't really do much of anything. The higher cam profile is optimized for higher rpms anyway.
I know on my B16A I lowered it from 5800 to 5300, but that was while dyno-tuning the cam gears and the fuel curves w/ the V-AFC. Smoothed out the"dip".
Old Apr 21, 2008 | 07:07 PM
JDMishEK's Avatar
Default Re: (.illwhitecoupe.)
its not a turbo or nitrous. its not gonna freaking kick. when tuned properly vtec will be a smooth transisition not like you went from half to full throttle at 5krpms. common now
Old Apr 21, 2008 | 07:15 PM
unsungfate's Avatar
i would say it "kicks" between 5.5k and 6k depending on load.
mine used to "kick" on my b16 at 5.5k at full throttle, but not its tuned to kick at 6k and red lines at around 10k
Old Apr 21, 2008 | 07:34 PM
gamby's Avatar
Default Re: (JDMishEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMishEK &raquo;</TD></TR><TR><TD CLASS="quote">its not a turbo or nitrous. its not gonna freaking kick. when tuned properly vtec will be a smooth transisition not like you went from half to full throttle at 5krpms. common now</TD></TR></TABLE>
Exactly. People confuse "more noise" with "NAWZZZSZZZZ"
arcivic90
Jan 21, 2010 06:20 PM
K20Z3CivicSiVTEC
Honda Civic (2001 - 2005)
May 19, 2008 08:34 PM
Brown-tec
Nov 13, 2005 08:39 PM
cookci
21
Mar 31, 2004 05:35 PM
blackccoupe
81
Nov 20, 2003 02:07 PM
