94 LS motor + 91 STD chassis - harness MAP sensor
Old Apr 20, 2008 | 07:47 PM
B18EG6's Avatar
Default 94 LS motor + 91 STD chassis - harness MAP sensor
Hello-
Hopefully a quick question, I am new to the EF world but have a boosted 95 hatch myself.
I am helping my friend build his EF and he sent his harness(es) away, and upon return we noticed there was no MAP plug on the harness. We had the harness incorporate the OBD0 - OBD1 conversion for the 94 LS ECU.
What's to do about the missing MAP plug?
Thanks in advance!
Seb
Old Apr 21, 2008 | 04:41 AM
JScott3d's Avatar
Default Re: 94 LS motor + 91 STD chassis - harness MAP sensor (B18EG6)
There should be a map. Its just one on the intake for a stock motor it bolts to the firewall if i remember correctly
Old Apr 21, 2008 | 07:28 AM
jlicrx's Avatar
the MAP sensor connector is not on the engine harness - the wires and connector just come out of the firewall - if you have a MAP on top of the throttle body, you need to extend the wires on the MAP connector so that it will plug in - the wires for the MAP are white, yellow/red and green/white -
Old Apr 21, 2008 | 08:07 AM
B18EG6's Avatar
Default Re: 94 LS motor + 91 STD chassis - harness MAP sensor (jlicrx)
ahhhhh I see now. Awesome, I will take a look at it when I return home tonight, thanks for clarifying that!!!!
sscivicsi
Mar 1, 2010 08:10 PM
hammergunner
Feb 22, 2009 05:12 PM
LS94tegra
Oct 13, 2008 05:17 PM
0ldsk00lef
Aug 22, 2007 08:55 PM
rpm9100
May 12, 2003 11:14 AM
