How do I put in my aftermarket water temp gauge?
Old Apr 20, 2008 | 05:56 PM
Preludes'R'Us's Avatar
Default How do I put in my aftermarket water temp gauge?
Get ready for a newbie question! I have an OBDI h22a motor. Is there anyway to put in an aftermarket temperature gauge without throwing a code? If there is which spot on the block do I put the sending unit from my new temperature gauge in?
All help is much appreciated!
Thanks,
Rob
Old Apr 20, 2008 | 06:16 PM
Default Re: How do I put in my aftermarket water temp gauge? (Preludes'R'Us)
to add to that. The gauge that I purchased only came with the nipple (and wires to make the gauge light up, which I already wired to my dimmer switch).
Old Apr 20, 2008 | 06:25 PM
Hawkze_2.3's Avatar
Here's how I installed my Defi temp gauge if it helps at all...
Old Apr 20, 2008 | 07:24 PM
oranginal's Avatar
Default Re: How do I put in my aftermarket water temp gauge? (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Here's how I installed my Defi temp gauge if it helps at all...
did you still use the stock signal/gauge...could you get a T and run both here?
Old Apr 20, 2008 | 08:15 PM
Hawkze_2.3's Avatar
Default Re: How do I put in my aftermarket water temp gauge? (oranginal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oranginal &raquo;</TD></TR><TR><TD CLASS="quote">
did you still use the stock signal/gauge...could you get a T and run both here?</TD></TR></TABLE>
I got rid of the stock temp gauge. I don't know how you could run a tee because the sender has a little tab that goes out into the coolant flow, and if it was inside a little tee I wouldn't think it would get the right temp not being in the flow..... Tapping another port into the head would probably be best.
Old Apr 21, 2008 | 10:28 AM
vlang29's Avatar
if you want to keep the stock temp gauge operational, tap 1/8 NPT threads into the water outlet neck on the front of the head for the new gauge sender.
Westnile
Honda Civic (2006 - 2015)
13
Sep 2, 2007 08:22 AM
NAmodified
Apr 3, 2007 02:08 PM
Wasabithegosu
Jun 23, 2005 11:33 AM
Another B16
Oct 1, 2002 01:42 PM
