losing power going up hill
Old Apr 20, 2008 | 05:55 PM
maal15's Avatar
Default losing power going up hill
i have a 96 y8 and we took a trip yesterday while driving i noticed that when i would go up hill i would loose a of power. i would be in 5 and would have to drop down to like 3 or some times lower. also my car idles below 1 should i change the fuel filter.
Old Apr 20, 2008 | 06:02 PM
pliskin679's Avatar
Default Re: losing power going up hill (maal15)
welcome to having a 4 banger :D
Old Apr 20, 2008 | 06:07 PM
icemyst01's Avatar
Default Re: losing power going up hill (pliskin679)
could be lots of things.... but yes filter, plugs, wires... but also part of driving a d series... my B series doesnt have that issue
Kurly's Avatar
its called owning a honda.. only fix is a big displacement v8... or a "souped" up b-k series.. =]
Old Apr 20, 2008 | 06:13 PM
z6hatchboy's Avatar
Do routine maintence first: filters, plugs, ect.. Finally get a valve lash adjustment, thats what helped me the most. After i rebuilt i had to pull hills that i'd normally do in 5th and 4th in 3rd, and my idle wasnt good. Adjusted the valves and was good to go.
Old Apr 20, 2008 | 06:21 PM
H22Ej1's Avatar
Shenanigans
Default Re: losing power going up hill (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Do routine maintence first: filters, plugs, ect.. Finally get a valve lash adjustment, thats what helped me the most. After i rebuilt i had to pull hills that i'd normally do in 5th and 4th in 3rd, and my idle wasnt good. Adjusted the valves and was good to go.</TD></TR></TABLE>
hes asking y he has to take hills in 2nd or 3rd instead of a higher gear, if im reading your post right your saying matinence allowed you to take hills in a lower gear...
any matter, op this is typical of any car, a lower gear is better for hills and will cause less bogging, you just happen to notice it alot more in a torqueless sohc
Old Apr 20, 2008 | 06:26 PM
dorkjoey's Avatar
Default Re: losing power going up hill (H22Ej1)
Same effects me.
Old Apr 20, 2008 | 06:28 PM
maal15's Avatar
thanks man everyone pretty much help me out on this one.
fsg231
Aug 25, 2009 06:05 PM
4drslow
73
Oct 4, 2006 01:46 AM
BigZ88
Dec 3, 2003 05:50 AM
slowman
Jan 22, 2003 12:56 PM
Duck Sauce
Feb 11, 2002 08:50 AM
