Free flow air system
Old Jul 11, 2002 | 11:54 PM
TypeR Chris's Avatar
Default Free flow air system
What about the "air-intake" system used in racing itr's - getting air through the position where normaly one of the lights fits in? I think it's a perfect position for getting cold air!!!
Does anyone know how that system is build up?
Old Jul 11, 2002 | 11:56 PM
Rhetoric's Avatar
Default Re: Free flow air system (TypeR Chris)
My friend does something similar. He cut out his high beam light and ran a funnel connected to his stock intake.
Old Jul 12, 2002 | 02:46 AM
DutchITR1689's Avatar
Someone on this board did the similar. He cut his headlight in two and removed the high beam. And a pipe is going straight into his stock airbox.....
Old Jul 12, 2002 | 02:48 AM
pLaYbOi's Avatar
New User
Default Re: Free flow air system (DutchITR1689)
just hope theres some kinda good filter behind that big hole..
otherwise
Old Jul 12, 2002 | 03:10 AM
uNF$@#!'s Avatar
Default Re: Free flow air system (pLaYbOi)
otherwise
...there is one, located in the airbox.
Old Jul 12, 2002 | 03:35 AM
Asahi's Avatar
This was discussed a LONG LONG (before the search goes back to) ago.
The headlight is a place of low pressure and therefore isn't all that great of an intake area. It was even pointed out that at the right speed the air travelling across the hole can cause a vacuum type flow and pull air away.
From the same study they showed that farther down towards the middle of the bumper (top to bottom) was a better place to pull air.
This was all discussed here and most vtests were quoted from T.O.O Board where Larry from endyn did the testing.
Old Jul 12, 2002 | 03:43 AM
Turtle's Avatar
Default Re: Free flow air system (Asahi)
There was a good thread on this last year. The guy that did it (don't know if he's still around) used a foam filter, and I can still here his comment "It's Cleanable! ". It's was a really good install; maybe he will chime in on this thread and hopefully put up the good pics that he had.
-B Who thinks this is great for track, but not for a DD.
Old Jul 12, 2002 | 05:07 AM
EagleR's Avatar
Default Re: Free flow air system (401-2001)
Yeah that would be a serious bee ach on the street....
Old Jul 12, 2002 | 05:23 AM
Dr Pooface's Avatar
Default Re: Free flow air system (EagleR)
IM Chris, he's done it.
Old Jul 12, 2002 | 06:55 AM
BSQ's Avatar
BSQ
Here is my "ram air" setup. It is a little bit more "streetable" since you are not eliminating one of the headlights. I primarily use it on the track, but I have used it on the street a few time. It connects to my DIY "Icebox" ( http://www.geocities.com/bretq/DIY_Icebox_CAI.html ) and it takes about 5-10 minutes to switch the stock turn signal lense with the "ram air" turn signal duct. Here are a few pictures:
Old Jul 12, 2002 | 09:22 AM
NINJA's Avatar
Default Re: Free flow air system (BSQ)
How did you hollow the turn signal?
Old Jul 12, 2002 | 09:58 AM
Flux's Avatar
Default Re: Free flow air system (NINJA)
http://integra.vtec.net/geeser/cold_air.html
Old Jul 12, 2002 | 11:03 AM
Ex-ITR5874's Avatar
I`m using a ram air system made if carbon.
A carbon funnel in the bumper leading directly to a custom made carbon airbox.. soon. Still waiting for the parts... There should be nothing better.
Old Jul 12, 2002 | 11:38 AM
ITR21's Avatar
Default Re: Free flow air system (ITR1858)
i dont think id do anything like that unless i can take it off for the stree.....i dont wanna be driving around the street with a funnel in my light.
Old Jul 12, 2002 | 11:44 AM
BSQ's Avatar
BSQ
I used a band saw to remove the lense cover from the front bulb and to cut off the bulb socket from the back of the turn signal .
Old Jul 13, 2002 | 07:15 AM
I like that!!! Very cool... i think i will try this version, 'cause i wanna use it for street and track driving!!!
Old Jul 13, 2002 | 07:32 AM
Edwin's Avatar
That's the coolest RAM air intake I've ever seen!
Awesome job man!
Old Jul 13, 2002 | 07:43 AM
Ex-ITR5874's Avatar
Default Re: Free flow air system (Edwin)
The funnel is too small.... use a funnel located in the bumper.
Old Jul 14, 2002 | 09:13 AM
Connecting to the bumper would be easier... the problem will be:
i wanna go directly to the throttle body, without using the air filter for track racing and i wonder if it's possible to do that without damaging the motor... for sure it's the best performance gain!!!
piggydog
Oct 13, 2005 01:30 PM
turbosi03
Jun 18, 2005 05:36 AM
Bull_head360
24
Apr 12, 2005 10:58 AM
speed daemon
Dec 4, 2003 06:29 PM
Solipsist
Jan 10, 2003 03:14 PM
