Where to get finned tubing? Need help please.
I have been searching for about 3 weeks now to find a place to sell a small amount (4 feet) of finned aluminum tubing with no luck what so ever. I have searched the entire internet over and nothing.
Does anyone know where to get some of this stuff? Anyone have some sitting around to sell?
you need a place that specializes in extrusions
this is an extrusion i was working with for a while and welding up one of the first ones above.
what size do you need? i used to work for a company that specialized in retubing heat exchangers, so i know where there is a ton of that ****.
it's not aluminum pipe though, usually either mild steel or stainless steel tubing. they strip the aluminum fins from the used stuff and sell it to recyclers, so i am sure i could get my paws on a small chunk of it for you if you wanted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSI56 »</TD></TR><TR><TD CLASS="quote">you need a place that specializes in extrusions
this is an extrusion i was working with for a while and welding up one of the first ones above.</TD></TR></TABLE>
Not enough surface area on those types.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROTARY »</TD></TR><TR><TD CLASS="quote">http://www.cainind.com/media/P...g.pdf</TD></TR></TABLE>
Tryed that like a week ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cua0 »</TD></TR><TR><TD CLASS="quote">what size do you need? i used to work for a company that specialized in retubing heat exchangers, so i know where there is a ton of that ****.
Do they ever get any all aluminum stuff? Kinda hard to weld stainless to aluminum.
This is the size I am looking for or very close to it for anyone that knows of some.
A (2) 13" or (1) 26"
B 1/2" - 5/8"
C (2) 12" or (1) 25"
D 1.5"
E 1/2" not very important
Minimum of 12 fins per inch, Embedded would be best but L foot or edge tension would be fine.
B 1/2" - 5/8"
D 1.5"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper »</TD></TR><TR><TD CLASS="quote">HVAC supply shop/ware house
Modified by JDMs1eeper at 6:44 PM 4/22/2008</TD></TR></TABLE>
Nothing from the ones I've tried so far. There is a metal scrap yard about a half an hour from me that maybe just might have some but I doubt it. I have to pick up some plate from him anyhow for a welding table.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker »</TD></TR><TR><TD CLASS="quote">
There is a metal scrap yard about a half an hour from me that maybe just might have some but I doubt it.</TD></TR></TABLE>
Nothing.....
Someone has to know something, this isn't nasa only parts or anything.
Nothing.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper »</TD></TR><TR><TD CLASS="quote">ill look at the supply shop tomorrow if i swing by either one of them. If they have it, I'll get back with you.</TD></TR></TABLE>
That would be awesome man!
I have a couple small stores close that i thought of today that I have to check out.
^ nothing, I did get a couple more leads though for a couple more places I have to check.
For heat exchangers on a jrsc. However I have already ordered some off ebay. They are called laminova cores. Supposed to be more efficient than the standard finned tubing so we will see.
http://cgi.ebay.com/ebaymotors...h=013
Race Egr
Welding / Fabrication
10
Aug 3, 2005 02:04 PM
