93 del sol want to put ls in
Old Apr 20, 2008 | 03:05 PM
howard12's Avatar
Default 93 del sol want to put ls in
i was told i need a diff. shift linkage if i put an LS in my del sol witch one do i need? i have the d16 z6 in it now
Old Apr 20, 2008 | 03:09 PM
97Ej6mike's Avatar
You need B-series mounts, linkage and proper ECU (p75). Also, the motor should come with B-series header, but if not, you need to get your hands on some.
Old Apr 20, 2008 | 04:55 PM
howard12's Avatar
Default Re: (97Ej6mike)
i have all that be sides the linkage but what would it come out of
Old Apr 21, 2008 | 08:37 PM
97Ej6mike's Avatar
Default Re: (howard12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by howard12 &raquo;</TD></TR><TR><TD CLASS="quote">i have all that be sides the linkage but what would it come out of </TD></TR></TABLE>
Integra. Any b-series linkage is really what you need.
Old Apr 22, 2008 | 08:24 AM
VSMhatchy's Avatar
Default Re: 93 del sol want to put ls in (howard12)
I had a delsol at one point in time with a d15b and I swapped it for a LS. All you really need is the shift linkages from a b16 delsol and the A/C bracket from the b16 delsol. You also need to get Integra motor mounts and rear t bracket. you also will need to get the tranny side torque mount. I bought all my mounts and brackets and the shiftlinkages brand new. Your harness will work fine on it.
Old Apr 22, 2008 | 08:53 AM
tanaka2's Avatar
Default Re: 93 del sol want to put ls in (VSMhatchy)
you need to goto honda and specifically ask for a del sol dohc vtech shift linkage. its shorter than the intergra its like $150
Old Apr 22, 2008 | 09:37 AM
fillipo's Avatar
Default Re: 93 del sol want to put ls in (tanaka2)
exactly what he said^ did that for my old sol. cost me 160 at the time i believe
Old Apr 23, 2008 | 09:55 AM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tanaka2 &raquo;</TD></TR><TR><TD CLASS="quote">you need to goto honda and specifically ask for a del sol dohc vtech shift linkage. its shorter than the intergra its like $150</TD></TR></TABLE>
VTEC, no H.
Sochiro Honda himself turns over in his grave everytime VTEC is mispelled, and then god smites a kitten.
Any B-series linkage should be what fits, as far as im concerned.
monsterb18b
Aug 11, 2008 06:11 AM
Jose-aka-Pedro
May 28, 2007 11:11 PM
BRG+Honda=JDM
May 20, 2007 09:58 PM
hotimportcrx
Nov 3, 2005 09:51 AM
DelSol808
Oct 26, 2002 10:50 AM
