Why am i overheating
Old Apr 20, 2008 | 10:21 AM
f1fever's Avatar
Default Why am i overheating
Is it my fan ?
when i am stopped at a redlight i would overheat from quarter under to quarter over half and even sometimes full top. but ones i start driving at a decent speed 70+ it will drop back to under half for awhile and then it would do the same thing over and over and over
how do itell if my fan is working i havent heard it spin but i havnet been paying attention
but if its not the fan what could it be going up and down up and down
Old Apr 20, 2008 | 12:10 PM
th3pwn3r's Avatar
Default Re: Why am i overheating (f1fever)
What you can do is open up the hood and see if the fan is working, that'd be a good start. Check your coolant level and also check your thermostat and hoses for problems.
Old Apr 20, 2008 | 12:55 PM
Ahknodd's Avatar
Default Re: Why am i overheating (th3pwn3r)
What car do you have?
a ghetto way to check your fan is unplug it and use some jumper wires and jumper it to the battery and see if the bad boy spins up. If it doesn't then your fan is shot. If it does then you know it's good, but maybe the wiring circuit to the fan is bad. To check that, plug it back in and start your car. Let it warm up in your driveway and if it starts to over heat and the fan doesn't turn on then you know it's something in the circuit.
Did you check your fan's fuse?
Old Apr 20, 2008 | 03:34 PM
HONDAPARTSMANMIKE's Avatar
i would check your fan operation and check the thermostat.
94egR
Jun 16, 2008 11:18 AM
lPat
Sep 10, 2007 07:48 PM
mynameizstitch
10
Aug 30, 2007 08:15 PM
ctrld-kaos
Dec 7, 2006 05:22 AM
SpoonREVS
Jan 24, 2006 05:42 PM
