code 9 jdm crx with an obd 1 jumper
Old Apr 20, 2008 | 10:00 AM
88hfef8's Avatar
Default code 9 jdm crx with an obd 1 jumper
Hey need some answers, got a jdm crx with an obd1 jumper. At first it threw out code 22 and 21 so i ran the vtec switch and solenoid. There is some wires don't match on the jumper and stock harness. I wanted to know if anyone has used a jumper on a jdm crx. more info I check the wiring to the distributor, I've switched distributors, spec on the car is a jdm crx with a gsr swap and jspusa jumper
Old Apr 20, 2008 | 10:27 AM
jamison1486's Avatar
Default Re: code 9 jdm crx with an obd 1 jumper (88hfef8)
this is funny b/c i has the same codes last week...7, 9, 21, 22. code 9 means that there is probably something wrong internally with you dizzy. to my knowledge, code 9 pretty much means you need a new distributor.
Old Apr 20, 2008 | 10:44 AM
88hfef8's Avatar
Default Re: code 9 jdm crx with an obd 1 jumper (jamison1486)
i swapt out whit my friends dizzy and still the the same problem ..
Old Apr 20, 2008 | 11:36 AM
thevtecnician's Avatar
Code 9 is #1 cylinder position sensor. If you changed your dizzy already with one from a car without the same cel then the problem is with the wiring.
Old Apr 21, 2008 | 05:03 PM
88hfef8's Avatar
Default Re: code 9 jdm crx with an obd 1 jumper (thevtecnician)
thanks for all the help. one of the pins from the jumper broke off just jumped the jumper and the code went away
ADAMnQuickRDX
May 7, 2009 11:30 AM
GSR_hatch936
Sep 25, 2008 12:29 AM
rustbucketrex
Jun 28, 2007 06:43 AM
1_SC_GSR
Aug 14, 2006 10:24 PM
Sirex
Dec 8, 2003 09:26 PM
