Suspension & Brakes Theory, alignment, spring rates....
KYB AGX vs. tolico illumina
Old Apr 20, 2008 | 09:20 AM
88Snatch's Avatar
Default KYB AGX vs. tolico illumina
what is the better shock????????any opinions???????
Old Apr 20, 2008 | 09:33 AM
skynyrd006's Avatar
Default Re: KYB AGX vs. tolico illumina (88Snatch)
They are both great shocks. I prefer tokico illuminas because I have them
Old Apr 20, 2008 | 10:36 AM
88Snatch's Avatar
Default Re: KYB AGX vs. tolico illumina (skynyrd006)
thanks....anyone else?????
Old Apr 21, 2008 | 05:36 AM
88Snatch's Avatar
bump
Old Apr 21, 2008 | 02:52 PM
skynyrd006's Avatar
Default Re: (88Snatch)
Illuminas also have a lifetime warranty
Old Apr 22, 2008 | 10:00 PM
JDMDAEK's Avatar
Default Re: (skynyrd006)
There is no difference except the tokico has 5way adjustable and Kyb has 4. Both shocks are decent. But i would never roll on anything but KONI
Old Apr 22, 2008 | 10:55 PM
TOO MUCH TORQUE's Avatar
Default Re: (JDMDAEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDAEK &raquo;</TD></TR><TR><TD CLASS="quote"> But i would never roll on anything but KONI</TD></TR></TABLE>
Old Apr 22, 2008 | 11:13 PM
Tyson's Avatar
illuminas.
Old Apr 23, 2008 | 12:47 AM
bmoua's Avatar
i've pushed both shocks to there limits and the illuminas are the better shocks.
Old Apr 23, 2008 | 08:40 AM
EK4civichatch's Avatar
Illuminas are great shocks...
Old Apr 23, 2008 | 03:05 PM
TheTealHatch's Avatar
Default Re: (EK4civichatch)
Only used illumina and they were great shocks. Never used the agx but I hear there good too
Old Apr 23, 2008 | 04:01 PM
skynyrd006's Avatar
Default Re: (TheTealHatch)
I use illuminas with ground control coilovers and i love it. Ride is firm and never bouncy.
Car handles like its on rails too I have had this setup for nearly two years with 0 issues.
Old Apr 24, 2008 | 03:33 AM
hatchyksp's Avatar
illuminas on a rex and a mr2. illuminas are way better.
agx can pop.
over all better ride with tokico'z
Old Apr 24, 2008 | 07:15 AM
HipHapa-Eg's Avatar
From: Where friends and family is all that matters, CA
i have KYB AGX's on my car and they were a nice ride, but not as agressive as i though so im getting some Functions lol.
Old Apr 28, 2008 | 12:06 PM
wlee112's Avatar
Default Re: KYB AGX vs. tolico illumina (HipHapa-Eg)
im riding on some illuminas and im lovin them considering upgrading to konis though.. but im sure you already know its Illuminas FTW
Old Apr 28, 2008 | 10:00 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDAEK &raquo;</TD></TR><TR><TD CLASS="quote">There is no difference except the tokico has 5way adjustable and Kyb has 4.</TD></TR></TABLE>
There are some rather significant differences between the two shown in the dyno curves, so "there is no difference" is a misleading and false statement.
Neither damper is "5-way adjustable," and I've never even seen such a thing.
Both are 1-way adjustable (full range compression and rebound simultaneously). In addition, some AGX models have 8 settings for the adjuster rather than 4 - but number of settings is often irrelevant in the grand scheme of things, because adjusters for low-end dampers are rather unreliable and often times changing settings won't actually change the damping curves at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i would never roll on anything but KONI</TD></TR></TABLE>
Then you'll only ever have a tiny sampling of the scores of different dampers available out there. While Koni is generally great, it's not the only worthwhile brand out there.
Old Apr 29, 2008 | 10:29 AM
r3D2_Fan's Avatar
Default Re: (Targa250R)
I had both shocks before. I had the Tokikos in my 92 EG and the KYB on my 00 SI and they both worked great. But if I had to go with one I would have to say Tokiko... I personally liked the ride better but then again it could have been the difference in ride of both cars. The SI weights over 1,000 pounds more than the EG. A good place for install if you want real dial in numbers will be West End Alignment in Gardena. Darin works on my S2K and he's the best out there!
Old Apr 29, 2008 | 11:07 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (r3D2_Fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3D2_Fan &raquo;</TD></TR><TR><TD CLASS="quote"> The SI weights over 1,000 pounds more than the EG. </TD></TR></TABLE>
Erroneous.
Old Apr 29, 2008 | 01:23 PM
bpr0422's Avatar
Comes down to budget, and what you ultimately what you want the car to do...
If you look at dynos of both, the iluminnas have a more "effective" adjustment range compared to the agx,
but the agx is much more linear...
now my personal benchmark for comparing the graphs, was the PIC graph... because of the reviews of PIC coil-overs here on ht...
People said that the PIC coil-overs made the car more predictable, and just easier to drive, the PIC select dampers are very linear.
Cause of this, i'm leaning towards the agx's - and they fit my budget better... I'd rather have a predictable car, than a comfortable ride...
If I had 1200 to spend on coil-overs, i would go with PIC selects, but I don't have that kind of money.
Old Apr 29, 2008 | 03:57 PM
taeng's Avatar
I was told AGX is better
j.dizzle
May 6, 2007 04:25 PM
j.dizzle
10
May 6, 2007 01:27 PM
igone916
Sep 3, 2004 09:35 AM
HONDA-2NR
Jan 28, 2004 06:30 PM
redteg1
Dec 2, 2001 05:30 PM
