Custom Piston Machining
Im looking at this site and there are a few opinions of things that im not 100% sure about.
http://www.wiseco.com/PDFs/Cat...o.pdf
If you look at the bottom it says :
Ceramic Dome Coat
Skirt Coat - Moly / Xylan
Anodize / EN Plate
XLS Milling
Anti-Detonation Grooves
Pressure Seal Groove
Gas Port L / V / Both / Pres Eq. Groove
Im familiar with some of these things but could anyone go through them and explain the benefits and disadvantages of them
Ceramic Dome Coat
Anodize / EN Plate
XLS Milling
http://forums.nasioc.com/forum...07570
gas porting is a process of drilling tiny holes into the top of the piston so that the pressure created in the cylinder will help seal the rings even more.
shoot DonF an IM
shoot DonF an IM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">http://forums.nasioc.com/forum...07570
shoot DonF an IM</TD></TR></TABLE>
Gas porting is only used in drag motors right?
magic hat #9
Dec 31, 2003 12:57 PM
