OBD P0750 Code - Problem in Hydraulic Control System of Solenoid valve A
Old Apr 19, 2008 | 11:28 PM
uifksh's Avatar
Default OBD P0750 Code - Problem in Hydraulic Control System of Solenoid valve A
Hi
Can someone give me information about the problem in Hydraulic Control System of Solenoid valve A (P0750).
My car stalls at low speeds.
Any information will be really appreciated.
Thanks
Nitin
Old Apr 20, 2008 | 04:24 PM
jdeemseerx's Avatar
Default Re: OBD P0750 Code - Problem in Hydraulic Control System of Solenoid valve A (uifksh)
No1 can diagnose this problem for you over the computer, sorry man.
Heres some things to think about though.
1.Faulty shift solenoid.
2.Faulty converter Assembly.
3.Blockage in a fluid passage to Solenoid A
4.Leaky seal inside trans causing lock up.
Depending on the year of your car some diagnostics can be done with computers. (OBD2)
Even if it is just a solenoid, if its been having problems for a while your better off just taking it to a trans shop or a dealership and having your trans rebuilt. Or take a risk and get a junkyard trans.
BTW.. Do you have reverse?
darkvibe
May 28, 2013 08:01 PM
andycap7
Apr 3, 2010 02:19 AM
TScully
Acura TL, RL & ZDX
Feb 28, 2008 05:34 AM
ravens31
Jul 8, 2004 09:46 AM
