Transmission
Old Apr 19, 2008 | 11:13 PM
Christopherian1982's Avatar
Default Transmission
I wanna drained my old manual transmission fluid and put new fluid in... I need pics and instruction on how to do it... Btw its a stock b16
Old Apr 19, 2008 | 11:21 PM
philosofy1's Avatar
Default Re: Transmission (Christopherian1982)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christopherian1982 &raquo;</TD></TR><TR><TD CLASS="quote">I wanna drained my old manual transmission fluid and put new fluid in... I need pics and instruction on how to do it... Btw its a stock b16 </TD></TR></TABLE>
though it says for a d-series motor, it's the same exact step and tranny set up on a b-series.
https://honda-tech.com/zerothread/2127518
Old Apr 19, 2008 | 11:59 PM
eklsvtec111's Avatar
get any civic manual it will tell and show you .all you have to do is get a ratchet dont put any socket on it, there is a bolt that has a square opening sitting sideways on the bottom of your trans (bottomside) this is the drain hole . the only way to get this bolt out is with a ratchet, the ratchet has a sqaure end on it, this sqare end is where you would normally put a socket on it but you dont need any socket because the ratchet will literally plug into the bolt and dont worry its the only bolt like that on the entire car. so pull the bolt out, let old oil drain. when its done draining put the bolt back in. Now here's a tip the book wont tell you. to refill the trans you have 2 options, the book way(which means you have to poor oil in from the side at another bolt hole located above and behind the drain hole) or you can do it the easy way! locate your speed sensor its located at the top of the trans (you may have to pull your intake out of the way) its sticking strait up on the back side of the trans (topside) with a 3 wire plug on it. unplug it then you have to pull 1 10mm bolt out (EASY!) once the bolt is out pull the sensor out if it feels stuck its not! wd40 it and wiggle it out. once its out you have an easy place to refill trans. now get a long funnel and start refilling, it takes 2+1/2 quarts to refill, I highly suggest using "syncromesh"(1 quart)and then 1+1/2 non sythetic 5w30 motor oil (all at autozone)or go to honda dealership and get "honda MTF"and pay 6.50 a quart. (dont use thick gear oil!) but i always use syncromesh cause it will help get rid of grinds and keep your sycro's in your tranny healthy! when your done filling the trans with whatever fluid put the speed sensor back in,put the 10mm bolt back in and finally plug the sensor back up(if you dont your speedo gauge wont work and youl get a check engine light so dont forget!)after all that your done! and you will acually enjoy doing it from now on cause you'll know it will be done right (jiffy lube will[freak] it up!)just remember tranys will last forever if fluid changed regularly and you dont power shift the hell out of it! tranny's are expensive especially
b series ones! good luck
Old Apr 20, 2008 | 04:39 AM
philosofy1's Avatar
Default Re: Transmission (eklsvtec111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eklsvtec111 &raquo;</TD></TR><TR><TD CLASS="quote">get any civic manual it will tell and show you .all you have to do is get a ratchet dont put any socket on it, there is a bolt that has a square opening sitting sideways on the bottom of your trans (bottomside) this is the drain hole . the only way to get this bolt out is with a ratchet, the ratchet has a sqaure end on it, this sqare end is where you would normally put a socket on it but you dont need any socket because the ratchet will literally plug into the bolt and dont worry its the only bolt like that on the entire car. so pull the bolt out, let old oil drain. when its done draining put the bolt back in. Now here's a tip the book wont tell you. to refill the trans you have 2 options, the book way(which means you have to poor oil in from the side at another bolt hole located above and behind the drain hole) or you can do it the easy way! locate your speed sensor its located at the top of the trans (you may have to pull your intake out of the way) its sticking strait up on the back side of the trans (topside) with a 3 wire plug on it. unplug it then you have to pull 1 10mm bolt out (EASY!) once the bolt is out pull the sensor out if it feels stuck its not! wd40 it and wiggle it out. once its out you have an easy place to refill trans. now get a long funnel and start refilling, it takes 2+1/2 quarts to refill, I highly suggest using "syncromesh"(1 quart)and then 1+1/2 non sythetic 5w30 motor oil (all at autozone)or go to honda dealership and get "honda MTF"and pay 6.50 a quart. (dont use thick gear oil!) but i always use syncromesh cause it will help get rid of grinds and keep your sycro's in your tranny healthy! when your done filling the trans with whatever fluid put the speed sensor back in,put the 10mm bolt back in and finally plug the sensor back up(if you dont your speedo gauge wont work and youl get a check engine light so dont forget!)after all that your done! and you will acually enjoy doing it from now on cause you'll know it will be done right (jiffy lube will[freak] it up!)just remember tranys will last forever if fluid changed regularly and you dont power shift the hell out of it! tranny's are expensive especially
b series ones! good luck</TD></TR></TABLE>
WHAT THE @#&*%!!!!!!!
damn, one look at this thing ans i lost interest in even reading it.
i get what you are trying to accomplish, but that's why we have the FAQ forum, just refer them to that.
Old Apr 20, 2008 | 07:26 AM
How much tranny fluid do i put in and how many quarts do i need to buy?
imadigitalgod
187
Apr 23, 2016 07:08 AM
airikkCRX
Jul 2, 2010 11:49 PM
98savage
Apr 6, 2007 10:03 AM
shinrachaos
Jan 14, 2006 12:27 AM
DamonBoost
Oct 27, 2001 02:28 AM
