gear- neutral without the clutch?!
Old Apr 19, 2008 | 11:11 PM
BB1LOViN's Avatar
Default gear- neutral without the clutch?!
Today as i was driving about 40mph on the freeway i accidentally shifted without the clutch and no grinding whatsoever happened. I tried it again at 40mph in 5th, 4th and 3rd. and still nothing. Are my synchros screwed up? is my clutch bad?.. pretty much i can shift out of gear without touching the clutch at all.
Old Apr 19, 2008 | 11:22 PM
speedracer9k's Avatar
there is nothing wrong, when you match the speed of your engine with the same speed of your trans gears you will be able to shift in and out of gears.
Old Apr 19, 2008 | 11:25 PM
BB1LOViN's Avatar
Default Re: (speedracer9k)
ive heard of that but would it be the if i did 40 in 4th, 40 in 3rd, and 40 in 5th too? havent tried it any other speed.
btw if you know other "spots" or speeds in which gears that do not require the clutch can you let me know as well?
Old Apr 20, 2008 | 01:58 AM
dagle's Avatar
Default Re: (BB1LOViN)
pulling out of gear is easier than putting into gear. dont try it tho. i think the magic number is between 3000-3500 for us.. dont quot eme on that.
Old Apr 21, 2008 | 05:21 PM
it can be any speed, you just need to know what gear your going into and what rpms it should be at when you shift into that gear at that speed. sorry its kinda hard to explain.
Old Apr 21, 2008 | 08:34 PM
BB1LOViN's Avatar
Default Re: (dagle)
so everything is fine with my tranny/clutch?
btw would i be gassing it or even touching the gas pedal when i do this?
Old Apr 21, 2008 | 09:15 PM
jlude90's Avatar
you'd be letting off the gas to be pulling it out of gear, and blipping the throttle to the proper RPMs putting it into gear
as prebiously stated, taking it out of gear is easy, putting it back in you'll get a whole lot of grindage, sounds like you got pretty lucky with no grinding
Old Apr 23, 2008 | 08:50 PM
BB1LOViN's Avatar
Default Re: (jlude90)
i havent tried putting it IN to gear. ive been pulling it out though
so pretty much this is normal for any manual car?
verycleanhatch
Oct 6, 2005 03:43 PM
eMpAtHy
Apr 18, 2005 12:39 AM
ActiveAero
16
Mar 5, 2002 07:44 AM
vtecguy
Oct 8, 2001 12:45 PM
FlipboiGSR
Sep 12, 2001 09:07 PM
