Gear Grinds
My clutch isnt worn out at all, and when i shift into first, second, and third its fine. but when i shift into fourth gear if i pull back too far on the shifter when im holding in the clutch it makes a grinding noise. i can shift into fourth without making the noise because i know not to pull it back too far but what the hell is the problem with it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmr828 »</TD></TR><TR><TD CLASS="quote">My clutch isnt worn out at all, and when i shift into first, second, and third its fine. but when i shift into fourth gear if i pull back too far on the shifter when im holding in the clutch it makes a grinding noise. i can shift into fourth without making the noise because i know not to pull it back too far but what the hell is the problem with it?</TD></TR></TABLE>
why are pulling to far on the shifter anyway? that might be your problem right there. a syncro could and most likely is damaged.
i suggest you change out your MTF and see what happens.
Nemesis415
Aug 16, 2008 11:18 PM
