Classic Hondas All Pre-1988 Hondas.
Can you make change the voltage on your alternator?
Old Apr 19, 2008 | 06:04 PM
gonzalezjk's Avatar
Default Can you make change the voltage on your alternator?
Hi. I have a Honda CRX Si 87 went to Auto Zone, they checked the alternator and the regulator is only trowing 11.8 volts. Is there any way I can change the voltage without replacing the alternator? If I have no choice but to replace the alternator, where is the cheapest place I can find this alternator? Thanks.
Old Apr 20, 2008 | 02:40 AM
Bozwell's Avatar
Default Re: Can you make change the voltage on your alternator? (gonzalezjk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gonzalezjk &raquo;</TD></TR><TR><TD CLASS="quote">Hi. I have a Honda CRX Si 87 went to Auto Zone, they checked the alternator and the regulator is only trowing 11.8 volts. Is there any way I can change the voltage without replacing the alternator? If I have no choice but to replace the alternator, where is the cheapest place I can find this alternator? Thanks.</TD></TR></TABLE>
check the battery is good first as a faulty battery will confuse the altenator (i have had this many times on various cars) otherwise it's a recon or new altenator
also if you do any welding on the car , disconect or remove the altenator , it only takes 10 minuites to remove (welding can pop the diodes, i did this on mine )
Old Apr 20, 2008 | 10:23 AM
gonzalezjk's Avatar
The battery is brand new. I just installed it yesterday and test drive the car with no problems. I then disconnected the negative pole of the battery with the car still on and the car turned off. Thats when I decided to check the alternator.
Old Apr 20, 2008 | 12:35 PM
Bozwell's Avatar
Default Re: (gonzalezjk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gonzalezjk &raquo;</TD></TR><TR><TD CLASS="quote">The battery is brand new. I just installed it yesterday and test drive the car with no problems. I then disconnected the negative pole of the battery with the car still on and the car turned off. Thats when I decided to check the alternator.</TD></TR></TABLE>
it's actually not a good idea to disconect the battery with the engine running as this can also damage an altenator (a cut off switch for racing will have a resistor wired in to keep the load on the altenator when the battery is switched off when running for this reason)
sounds like you need a new altenator and don't test it this way again!
HTH
Old Jun 17, 2008 | 03:22 PM
rdeezy78's Avatar
That does mean you have a bad alt. Replace and charge the batt. You should be good to go.
ITR198
Honda S2000
Jun 18, 2008 04:13 AM
freeofparanoia
Oct 20, 2003 08:51 PM
bonta-kun
May 12, 2003 06:08 PM
