Couple quick questions about the F23 block!
Old Apr 19, 2008 | 05:48 PM
Honda_Fanatic's Avatar
Default Couple quick questions about the F23 block!
I am thinking about using an H22a4 crank and rods with some shelf pistons to get me to about 13:1 compression.
What is the largest bore recommended for boring?
Would I be better off using the F23 crank and rods?
Anything else I should be aware of before doing this?
Thanks
Old Apr 21, 2008 | 03:33 PM
Turbowa's Avatar
Default Re: Couple quick questions about the F23 block! (Honda_Fanatic)
You can safely bore out to 87mm. What is it that your wanting to accomplish with this motor to need 13:1 comp?
Side note you would be much better keeping the F23 crank and rods.
Old Apr 22, 2008 | 06:54 AM
Default Re: Couple quick questions about the F23 block! (Turbowa)
13:1++ E85 build!
I was worried about the strength of the F23 rods, that is why I considered the a4 parts!
Old Apr 23, 2008 | 07:25 AM
Turbowa's Avatar
How high do you plan on reving? If its not to high you'll be ok using the F23 rods. If its any thing over 7000. I would go with after market rods. There are no rod bolts avalible for that motor.
lunatics209
Jun 12, 2008 01:38 AM
slammedcoupe
Jul 18, 2004 09:49 PM
slammedcoupe
Jul 18, 2004 06:53 PM
gsr98vtec
Jan 11, 2002 05:16 AM
