Transmission noise
Old Apr 19, 2008 | 05:05 PM
Fat Chick Magnet's Avatar
Default Transmission noise
Hey guys I'm about to replace my clutch on my 97 JDM ITR motor with OEM exedy and 7.5lb fidenza flywheel. Only problem is my transmission makes a weird whining sound..sounds similar to a supercharger no joke. And 2nd after beating on my car for a while during full stops the transmission makes weird chattering noises and once i press down on the pedal the sound goes away..I did re-search and a lot of people were mentioning on old threads that its the bearing inside the transmission..any suggestions would help.
Old Apr 19, 2008 | 05:15 PM
totsie7944's Avatar
Default Re: Transmission noise (Fat Chick Magnet)
Hmmm well my transmission made that whining sound right before it destroyed itself beyond repair internally. Did you have any bad mishifts recently?
I believe as well that if "noises" stop when you pushing the clutch in it could be either the throw out bearing or the inputshaft bearing....I will have to look it up again and check, I cant remember which is what.
Honestly, it sounds like you should stop driving the car and drop the trans, open it up and have it all checked out just so you don't have yourself a blown tranny in a few miles.
Old Apr 19, 2008 | 05:40 PM
totsie7944's Avatar
yea man honestly I am not sure what to tell you because it sounds like regardless you gotta drop your transmission. If it were me, instead of trying to replace this part and that part, re-install, etc only to find its still making the noise, I would just drop it, take it apart and have it rebuilt. The chattering noise is what bothers me....
Old Apr 19, 2008 | 05:49 PM
Default Re: Transmission noise (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">yea man honestly I am not sure what to tell you because it sounds like regardless you gotta drop your transmission. If it were me, instead of trying to replace this part and that part, re-install, etc only to find its still making the noise, I would just drop it, take it apart and have it rebuilt. The chattering noise is what bothers me....</TD></TR></TABLE>
same here man. I wonder how much it will cost to re-build it.
Old Apr 19, 2008 | 05:59 PM
ITR.#1446's Avatar
if the noise goes away when pushing the clutch in its most likely the throwout bearing, did you put a new one in when you replaced the clutch and grease it?
Old Apr 19, 2008 | 06:15 PM
TPB's Avatar
TPB
Default Re: Transmission noise (ITR.#1446)
Actually when you depress the clutch pedal, it engages the throw out bearing. If that bearing has gone bad, a whining noise comes from it.
Old Apr 19, 2008 | 06:18 PM
vinuneuro's Avatar
Sounds like input shaft bearing.
Old Apr 19, 2008 | 08:47 PM
IntegrasAreBest's Avatar
Dont mean to thread jack but Im going through the same problem as well, I changed my master & slave cylinder and that didn't help so I'm going to buy a new clutch and see what happens. I dont have any noises but the pedal really starts to shake when I press the clutch. Yes I did have a bad miss-shift recently. The weird thing is when I start the car and attempt to put it into 1st it wont let me, but if I put it in 1st and then start the car, I can go. Weird eh? Oh and it only grinds at high rpm shifts, but since I'm scared to death of braking anything i drove it home shifting at 2k and garaged it. Thoughts?????
Modified by IntegrasAreBest at 11:55 PM 4/19/2008
Old Apr 20, 2008 | 01:34 AM
Clutch/flywheel haven't been changed at all. I assume everything is stock. I'm about to order a new OEM clutch and fidenza flywheel. The clutch comes with a new release bearing and piolet bearing so hopefully the whinning sound will go away along with the chattering sound.
Old Apr 20, 2008 | 01:35 AM
Default Re: (IntegrasAreBest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegrasAreBest &raquo;</TD></TR><TR><TD CLASS="quote">Dont mean to thread jack but Im going through the same problem as well, I changed my master & slave cylinder and that didn't help so I'm going to buy a new clutch and see what happens. I dont have any noises but the pedal really starts to shake when I press the clutch. Yes I did have a bad miss-shift recently. The weird thing is when I start the car and attempt to put it into 1st it wont let me, but if I put it in 1st and then start the car, I can go. Weird eh? Oh and it only grinds at high rpm shifts, but since I'm scared to death of braking anything i drove it home shifting at 2k and garaged it. Thoughts?????
Modified by IntegrasAreBest at 11:55 PM 4/19/2008</TD></TR></TABLE>
np man you're having the same problem so we're here to figure it out, but one way to find out is to either rip apart our tranny or take a risk and buy new clutch and hope the problem goes away.
Old Apr 20, 2008 | 06:40 AM
good point, hey take a look at this article:
http://www.team-integra.net/se...D=911
Old Apr 20, 2008 | 10:34 AM
John M's Avatar
Let me know what it tuerns out to be
im pretty sure it is the input shaft bearing or throwout
Old Apr 20, 2008 | 10:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegrasAreBest &raquo;</TD></TR><TR><TD CLASS="quote">good point, hey take a look at this article:
http://www.team-integra.net/se...D=911</TD></TR></TABLE>
thanks.
Old Apr 20, 2008 | 10:37 AM
I'll keep you posted, now I just have to wait for the clutch to arrive in the mail.
Old Apr 20, 2008 | 10:38 AM
Default Re: (John M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">Let me know what it tuerns out to be
im pretty sure it is the input shaft bearing or throwout</TD></TR></TABLE>
well i hope its just the throw out bearing. if its the input shaft bearing how hard is it to change it? anyone have a DIY on this?
Ill keep everyone updated with this thread once i place a order on my clutch end of next week.
Old Apr 20, 2008 | 11:54 AM
meots98itr's Avatar
Default Re: (Fat Chick Magnet)
your input shaft bearing needs to be replace. save some money and make sure you put honda parts (bearing). also work with a good shop that will clean the tranny housing instead of wiping and putting it together. expect to pay $400 + depending on shop/s.
Old Apr 20, 2008 | 10:37 PM
Default Re: (meots98itr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meots98itr &raquo;</TD></TR><TR><TD CLASS="quote">your input shaft bearing needs to be replace. save some money and make sure you put honda parts (bearing). also work with a good shop that will clean the tranny housing instead of wiping and putting it together. expect to pay $400 + depending on shop/s.</TD></TR></TABLE>
Old Apr 21, 2008 | 07:37 AM
yeah Im going to drop my car off at Acura. I'm tired of guessing what my problem is, I think its the input shaft bearing.
Old Apr 21, 2008 | 07:53 AM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegrasAreBest &raquo;</TD></TR><TR><TD CLASS="quote">yeah Im going to drop my car off at Acura. I'm tired of guessing what my problem is, I think its the input shaft bearing.</TD></TR></TABLE>
I'd at least try and pull the trans yourself man. I think Acura has a price of like $500 just to drop the transmission...
Old Apr 21, 2008 | 08:53 AM
yeah they just quoted me a price of $957. 1 day job.
Old Apr 21, 2008 | 02:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegrasAreBest &raquo;</TD></TR><TR><TD CLASS="quote">yeah they just quoted me a price of $957. 1 day job. </TD></TR></TABLE>
wow you can find people on HT who can do it for cheaper and know what they're doing.. thats what im doing im having it inspected by someone and quoted $400 to drop tranny/change clutch/input shaft bearing and he has plenty of vouches.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegrasAreBest &raquo;</TD></TR><TR><TD CLASS="quote">I'll keep you posted, now I just have to wait for the clutch to arrive in the mail.</TD></TR></TABLE>
2xb18c6
Jun 23, 2016 05:24 AM
usdmed9
May 17, 2011 10:46 AM
hondachick05
Aug 12, 2004 09:30 PM
TypeRuz
Nov 3, 2003 05:08 PM
dk127
Aug 27, 2003 11:41 PM
