B18A1 bogging at low rpm
Old Apr 19, 2008 | 05:01 PM
90crxef's Avatar
Default B18A1 bogging at low rpm
soft on the gas pedal in first or not in gear, the rpms drop and car trys to stall, you can hear the intake almost choke itself out. if i stomp the pedal theres no problem and when im moving its only in first gear, all others are fine. maybe old gas? i bought it from someone that had it sitting, i would guess mostly all winter (had a bad head gasket) i replaced it all, got the head milled, engine and coolant system flush and theres still gray smoke coming out of the exhaust, it smells really rich, any help? thanks
Old Apr 19, 2008 | 05:36 PM
90crxef's Avatar
Default Re: B18A1 bogging at low rpm (90crxef)
bump
Old Apr 19, 2008 | 09:08 PM
mtber's Avatar
1. Check to make sure your cam gears/crank is all lined up at top dead center.
2. Check your codes if you have any & resolve them.
3. Make sure you did not mix up your intake air temperature sensor plug with another plug causing you to damage your iat sensor etc..
Old Apr 20, 2008 | 02:07 PM
90crxef's Avatar
Default Re: B18A1 bogging at low rpm (mtber)
yea i had a feeling it was my timing cuz you can smell how rich its running, its just i'd rather not have to mess around with that AGAIN lol but i guess ill tear it down and double check. i took my plugs out and all 4 are brand new, like 3 miles on them tops and they're jet black.
Old Apr 20, 2008 | 03:07 PM
90crxef's Avatar
just checked it over, timing is dead on, all sensors are in correct place, still boggs...
Old Apr 20, 2008 | 06:05 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxef &raquo;</TD></TR><TR><TD CLASS="quote">just checked it over, timing is dead on, all sensors are in correct place, still boggs...</TD></TR></TABLE>
Are you throwing any codes ?
Old Apr 22, 2008 | 11:00 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxef &raquo;</TD></TR><TR><TD CLASS="quote">i took my plugs out and all 4 are brand new, like 3 miles on them tops and they're jet black.</TD></TR></TABLE>
Hmmmm...
Your engine may be running slightly rich. What are you using to tune?
Old Apr 23, 2008 | 04:26 PM
90crxef's Avatar
Default Re: B18A1 bogging at low rpm (b19coupe)
just have a SAFC hooked up to it, but now i need a tranny, [freak]in pot holes, bottomed out and now theres a dime size hole in the bottom of my tranny....
Old Apr 23, 2008 | 05:38 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxef &raquo;</TD></TR><TR><TD CLASS="quote">just have a SAFC hooked up to it, but now i need a tranny, [freak]in pot holes, bottomed out and now theres a dime size hole in the bottom of my tranny....</TD></TR></TABLE>
Give us more information on the vehicle.
I.e. injector size, motor setup
Your original post made it sound like you had a stock motor setup etc.
Jonathen Lee
Sep 13, 2018 06:58 PM
sepheroth
Aug 19, 2009 05:41 PM
mister.wong
Jan 14, 2009 03:48 PM
Gir
Oct 14, 2004 06:02 PM
kwik92hb
Mar 16, 2004 06:02 PM
