2000 si b16 into 96 ex?
Old Apr 19, 2008 | 04:44 PM
EquipedWithVtec's Avatar
Default 2000 si b16 into 96 ex?
ok my friend has a 2000 si with b16 only 35K!! now my other friend bought the tranny and all the other stuff but he still has the complete engine now will this work with my 96 ex coupe? is there anyway to put just the engine in and use the dseries tranny and ill get like a hondata ecu or something. If so which ecu to get? and is it legal to do that i no you can do the h2b h22 with b series tranny is there anyway to do that with my situation what is needed to make it ALL work because he only wants 400 for complete motor sounds good to me what do you guys think? need major help with this.
Old Apr 20, 2008 | 07:21 AM
chad's Avatar
Moderator
Default Re: 2000 si b16 into 96 ex? (EquipedWithVtec)
b16a obd2b engine into 96 ex...
you must use a B series tranny. I have an ls tranny that will work, not ideal but would work for 300 bucks.
you can't just use a d tranny on a b. i think there is a company that makes a b to d conversion but that will cost more than just buying a b tranny to start with.
your p28 will run the b16 but not great. you can get an ob2a to obd2b conversion harness and run the stock ecu or get an obd2a to obd1 harness and get a hondata system or a chipped ecu.
you'll need half shaft and b series axels, and shiftlinkage. other than that you wire harness will swap right on the the b16, but you might have to extend the wires.
crxsi361
Dec 22, 2009 11:19 AM
civic95hbvtec
Nov 25, 2007 05:59 PM
ABK
10
Dec 16, 2004 10:01 PM
gocivicgo
Jun 30, 2003 03:11 AM
CzanSOHC
Sep 5, 2002 07:22 AM
