brake noise
Ok, here is the deal... everytime after I put my car in reverse and use the brakes, my brakes make a loud pop noise the first time I use them in drive.
It only happens the first time after using the brakes in reverse, but it happens every time.
I have a 97 btw.
Has anyone else had this problem??? What the hell is it?
Thanks
Brian
I have a 97 btw.
Thanks
Brian
Did you get some cheap brake pads? Maybe when the person installed it did not fit it in correctly. Also, it might not be your brake pads... might be a bushing or something
the car is an auto and the pop happens the first time i brake in reverse, then the first time I brake in drive.
It sounds like it is coming from the front... almost like the calipers are being moved then popped back into place.
This may sound wierd, but as a last resort measure, check the splines on your hub. This sounds odd, but if a tooth has been stripped somehow, then it would allow the axle to jump, and it would make such a noise. I don't know why I thought of this, and I have no evidence to back this up, but as I said, if you cant figure it out, it is at least worth a check.
Nothing you can do about it. If you want to verify that this is the noise you can take some paper and put it on the top and bottom edges of the pads and the noise should improve. It won't last though as the paper will get pounded and fall apart.
