Injectors not working, bizarre situation
Old Apr 19, 2008 | 02:29 PM
EH3Civic's Avatar
Default Injectors not working, bizarre situation
D16z6
OBD1 harness
p28
So I am building a d16z6 powered dune buggy and I used a chopped up harness to work with. I did an initial wiring prior to placing everything through the new firewall, and it ran perfectly after about 30hours of working on it. I reran the wires through the firewall and loomed everything up, and now it doesn't work. The problem, I believe, is some sort of grounding issue. I eliminated some of the wires that I didn't THINK I was using, but apparently I eliminated one too many. I checked and am getting voltage on the YELLOW/BLACK wire to the injector when grounding to the frame (12V) and across the connector at the injector I get 7-9 volts as I should. I removed the fuel rail and pulled the injectors and there is plenty of gas through the rail but the injectors won't squirt.
Hopefully I haven't left out any other info. I can take pictures if it will help.
Old Apr 19, 2008 | 08:54 PM
EH3Civic's Avatar
Default Re: Injectors not working, bizarre situation (EH3Civic)
Problem solved. Nevermind.
civickid81
10
Feb 23, 2013 08:40 PM
bootlegcivic
Aug 6, 2005 10:07 PM
turbo_ef9
Jan 24, 2005 09:47 AM
RebelleadeR
Jun 7, 2002 12:29 AM
