CRX Rev Limiter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rangerxtrn »</TD></TR><TR><TD CLASS="quote">This is a newb question... Does a 1989 CRX Si have a stock rev limiter? D16A6? I don't want to find out the hard way...
Yes, I don't know of any Honda that doesn't (88-up anyway). Though this question seems pretty retarded to me, you say to find out the "Hard" way like your hoping to rev that high safely on a stock motor and make power?? If your motor was built enough to make power that high it would not be a worry since it would be" built" and tuned for it so that leaves me thinking your motor is stock and you plan on revving it to and/or past the rev limiter for what reason? Honda put the limiter in for a reason and anybody making power past that should know what the valve train can take
If you gotta ask on this one your likely gonna break something anyway.
...or maybe I'm wrong
</TD></TR></TABLE>Yes, I don't know of any Honda that doesn't (88-up anyway). Though this question seems pretty retarded to me, you say to find out the "Hard" way like your hoping to rev that high safely on a stock motor and make power?? If your motor was built enough to make power that high it would not be a worry since it would be" built" and tuned for it so that leaves me thinking your motor is stock and you plan on revving it to and/or past the rev limiter for what reason? Honda put the limiter in for a reason and anybody making power past that should know what the valve train can take
k i'm not retarded i was just wondering. I've built engines for mustangs and vintage pontiacs dude. This is the first "honda" i've owned and yes i know that the dirty d's drop off around 5800 rpms. I have another thread posted here about some building questions if you would like to give input here: https://honda-tech.com/zerothread?id=2280823
I am used to big displacement and carbs so the tuner world is new to me. that is why i'm asking questions...
Modified by rangerxtrn at 12:40 PM 4/19/2008
Well it actually has a cold rev limiter at 6800 and once it reaches operating tempurature it will jump to 7200... but I would hope that nobody on here would rev out a cold engine anyways
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFstyle »</TD></TR><TR><TD CLASS="quote">Well it actually has a cold rev limiter at 6800 and once it reaches operating tempurature it will jump to 7200... but I would hope that nobody on here would rev out a cold engine anyways
and lets not forget the "Type R" sticker clause that allows you to rev to 10,000 when properly applied.
...good info on the cold start, never knew that one
</TD></TR></TABLE>and lets not forget the "Type R" sticker clause that allows you to rev to 10,000 when properly applied.
Yes, they have a stock rev limiter on accelration, but NOT ON DE-ACCEL. So if you down shift like I have from 5th to first (or 4th, I dont remember) on the freeway, there is no limiter. So keep that in mind.
(Luckily I pulled it out of gear right when I hit 7k, And I didn't have my liscense yet and I was only like 15 or 16, That's why I made that newb mistake!
Oh, and as long as you have a stock ECU, there will always be a rev limiter!
)Oh, and as long as you have a stock ECU, there will always be a rev limiter!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stunna AARON »</TD></TR><TR><TD CLASS="quote">Yes, they have a stock rev limiter on accelration, but NOT ON DE-ACCEL. So if you down shift like I have from 5th to first (or 4th, I dont remember) on the freeway, there is no limiter. So keep that in mind.
ok
1. a rev limiter can be removed from a stock computer.
2.it dont matter if u down sift the ecu will still have a rev limiter in it,thats why honda put it there to pervet over reving.
3.your ecu must of had a removed rev limtier in it. ie egay mugen and spoon chips.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFstyle »</TD></TR><TR><TD CLASS="quote">Well it actually has a cold rev limiter at 6800 and once it reaches operating tempurature it will jump to 7200... but I would hope that nobody on here would rev out a cold engine anyways </TD></TR></TABLE>
thats about the closet thing ive seen to the right answer yet.you know why it has a cold rev limit of 6800? keeps u from over revving it on a cold motor and blowing the head gasket out!!
</TD></TR></TABLE>ok
The ecu revlimiter is electronic. If you down shift from say 5th to 2nd your rpms will be over the stock fuel cutoff. And yah you can remove the fuel cut off from a stock ecu but then it wouldn't technically be a stock ecu would it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician »</TD></TR><TR><TD CLASS="quote">The ecu revlimiter is electronic. If you down shift from say 5th to 2nd your rpms will be over the stock fuel cutoff. And yah you can remove the fuel cut off from a stock ecu but then it wouldn't technically be a stock ecu would it</TD></TR></TABLE>
idk ive never really done this before but my understanding is that the "rev limiter" is just fuel cut-off... and if thats true... it wouldnt stop the engine from over reving if you droped in to 2nd at too high of a speed... a rev limiter would only stop the engine from over reving under its own power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome »</TD></TR><TR><TD CLASS="quote">
...or maybe I'm wrong</TD></TR></TABLE>
I dont recall him saying he wanted to rev that high. In fact, if he wanted to rev that high, why would he bother asking? He would just go out and floor it if he didnt care. Possibly and more then likely while the car is still cold. Without any oil. With any other lubricants replaced with sand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFstyle »</TD></TR><TR><TD CLASS="quote">idk ive never really done this before but my understanding is that the "rev limiter" is just fuel cut-off... and if thats true... it wouldnt stop the engine from over reving if you droped in to 2nd at too high of a speed... a rev limiter would only stop the engine from over reving under its own power</TD></TR></TABLE>
correct.
When miss-shifting from 2nd to 3rd to 2nd (oops) the tranny can pull the motor up to 14,000 RPMs well over any limiter, there is no tranny limiter.
correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ »</TD></TR><TR><TD CLASS="quote">
I dont recall him saying he wanted to rev that high. In fact, if he wanted to rev that high, why would he bother asking? He would just go out and floor it if he didnt care. Possibly and more then likely while the car is still cold. Without any oil. With any other lubricants replaced with sand.</TD></TR></TABLE>
thanks for pointing that out... yeah I use the new synthetic sand lube on all engine surfaces now...
Actually, the car is using a quart every 1,000 miles. I want to do a mini-me and take the stock exhaust off, and new clutch, sleeves, pistons, rods, etc.
Skunk2 exhaust looks pretty cheap any good?
thanks for pointing that out... yeah I use the new synthetic sand lube on all engine surfaces now...</TD></TR></TABLE>
I heard that stuffs best in the business
Hey I'm a Honda Driver... only the best products goes in my ride...
</TD></TR></TABLE>Hey I'm a Honda Driver... only the best products goes in my ride...
BOSS-REX
Nov 18, 2004 05:29 AM
laosbboy
28
Jun 12, 2003 12:36 AM
